Well Ford's finally doing it..
#136
What about pressing that clutch pedal twice as often as it's designed? Do you know what a throwout bearing is? Do you know how it wears out?
With the exception of what TR is referring to with cold shifting, there's no point to double clutching a synchronized transmission.
#137
You think there's undue wear and tear put on your synchros by using the clutch only once?
But if you're using your truck as it was intended to be used, you will be double clutching under the conditions I've outlined in a previous post. Or you will get fed up with your driving skills, blame it on something else and settle on an automatic.
#138
Your throwout bearing lasts longer when you double clutch because (1) shifting is just as fast and (2) you're in neutral part of that time with no load on the bearing.
the throwout bearing is only loaded when you press the clutch... no matter what gear you are in, neutral or other.
The throwout bearing takes the most load while the clutch is in the motion of being pressed since that is the greatest axial force on it.
My transmission will last long longer if I use the clutch, even longer if I use it twice.
#139
