6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
TPMS question
Old Jan 17, 2010 | 08:59 PM
buck1974's Avatar
buck1974
TPMS question
I was thinking that all 2008 vehicles were standard with the tpms system as a standard feature. I recently replaced my tires and their were no TPMS sensors or bands around the rim. I believe I have a 08 job 1, was this an option for 08 and then standard the next year?
Old Jan 17, 2010 | 09:41 PM
LMS Residential's Avatar
LMS Residential
thats lucky imo, maybe they werent required on the 350s and up??? My 250 has them.
Old Jan 17, 2010 | 10:34 PM
pdombrowicki's Avatar
pdombrowicki
My 2008 F350 has them.
Old Jan 18, 2010 | 06:10 AM
Reave1's Avatar
Reave1
The TPMS was an option and did not become a mandatory install until late Job 2 i believe.
Old Jan 18, 2010 | 06:37 AM
R-T0r21on's Avatar
R-T0r21on
I don't have the TPMS either and SOOO glad I don't! Any vehicle I've seen with it has been more of a pain than anything else.They're too sensative. To put it on a pickup truck that may have varying loads and therefore varying desired tire pressure is down right stupid. When you're empty, you don't need, or want 80 psi in the rear tires. Conversely, you'll want more than, say 50psi when you're loaded. With my truck, I keep 80 psi in front because it's better for MPG's and easier on the steering. Plus it just looks too soft unless the air is up to max psi for the tire. I get full tread contact because these trucks are so front heavy. In the rear, I keep 50-60 psi when empty and can always air up when the load demands it. I won't have full tread contact with the rear tires unless they're aired down to 50-60psi when the truck's empty. BTW, having full tread contact is key in tire tread life, along with tire rotations at every service.
Old Jan 18, 2010 | 08:45 AM
Leo99's Avatar
Leo99
Have them on my 08 F-350 SRW and can't stand them. The cool weather set's them off. Dealers says too bad.
DaleBenson
All Things Towing
May 19, 2017 03:21 PM
smz
Escape & Escape Hybrid
Jun 1, 2016 10:51 AM
theoldwizard
May 13, 2016 02:12 PM
MisterCMK
2009 - 2014 F150
Mar 18, 2016 06:47 PM
Denola
Jul 5, 2015 11:45 PM
