My squeal continutes.... Need help!!!
Old Jan 17, 2010 | 07:34 PM
mxracer3276's Avatar
mxracer3276
Hey guys and gals, i started a thread a while ago about a whicked squeal that i had coming when i would turn. At first i thought it was the PS Pump, so i did a fluid flush, didnt get any better, but then it eventually got slowly better. Brought it to a buddies house, we took the tires up, put it on a lift and turned the wheel and it was still doing it. Then i started thinking it was the ball joints but i wasnt sure. Then it got better again, so i didnt think anything of it. Well, now it's back with a vengance. loud and annoying. There is no difference in how the truck turns, it is just a very loud squeal. The red circe is where the noise is coming from:
Old Jan 17, 2010 | 07:50 PM
F350-6's Avatar
F350-6
And it makes a noise turning side to side if you have both front wheels off the ground? What happens if you spray it with WD-40?
Lay a 2 x 4 next to your front tire on the outside. Place a crowbar over the 2 x 4 and stick it under your tire (with the wheel still jacked up) Press down on the crowbar so you're prying the tire upwards. Repeat this while someone watches this area. Is there any slop in there?
Old Jan 17, 2010 | 07:55 PM
mxracer3276
Whether the wheels are on or off the ground, it still makes the noise. I havent check to see if there is any slop in the wheel or not. Tomorrow i am going to go out there jack the front up and do something my buddy told me to try, and i will also try what you say to do Chris
Old Jan 17, 2010 | 08:55 PM
mueckster's Avatar
mueckster
I have seen ball joints that didn't have slack, but were just dry and squeaking. Try prying up on the rubber seal on the upper ball joint and spraying some lube in there, as suggested. It should work its way down into the socket and silence the squeak.
Old Jan 17, 2010 | 09:04 PM
big poppa's Avatar
big poppa
It does look like it could use a spraying, pretty dry looking..
Old Jan 17, 2010 | 11:50 PM
flatbeder's Avatar
flatbeder
Matt did that squealing noise start after you did the leveling kit?
Old Jan 18, 2010 | 06:01 AM
mxracer3276
The squealing noise just started not to long ago, and i did the leveling kit when i first bought the truck about 2 years ago.
woodie
Dec 21, 2012 10:24 AM
smithrock
Dec 11, 2012 10:22 AM
darkmage55
1997 - 2003 F150
22
Feb 19, 2010 01:43 PM
KevinC.
16
Jan 7, 2010 09:43 PM
f150v602
2004 - 2008 F150
Apr 18, 2008 07:43 AM
