cold lash adjustment for 223?
Old Jan 17, 2010 | 07:30 PM
F350moneypit's Avatar
F350moneypit
Does anyone know what the cold lash adjustment for a stock 223 I-6 should be? Can't get the engine to run until the valves are adjusted so the hot lash specs won't work.
Old Jan 17, 2010 | 10:52 PM
flipklos's Avatar
flipklos
57-64, 223, .019 hot is what I have.
Try .021-.022 cold. That should give you a bit of clearance for start up.
oldbrokecowboy's Avatar
oldbrokecowboy
Valve lash
Hi there. According to my "motor's manual" the lash is the same hot or cold .019 1960-1964. If this does'nt help let me know and we'll put our heads together and figure it out. OBCB
Old Jan 18, 2010 | 12:25 AM
flipklos's Avatar
flipklos
I would go with the broke guy. I just have a hot lash and a reasonable guess. Good luck hoss.
Old Jan 28, 2010 | 08:37 PM
spurredon's Avatar
spurredon
The Ford shop manual for a '60 223, says 0.019 cold or hot as well!
Old Jan 30, 2010 | 09:17 AM
F350moneypit
I will give 0.019 a try. Thanks for the info guys...
64rednwhite
May 5, 2015 09:14 PM
78 & 87 Super Cab
Apr 27, 2015 06:09 PM
C-700
May 28, 2014 10:32 PM
Argess
Sep 26, 2009 02:47 PM
Bikeitswift
Sep 22, 2004 10:23 PM
