any brake pros here
Old Jan 17, 2010 | 03:20 PM
drewdole's Avatar
drewdole
any brake pros here
on my 93 7.3 f250 i ve been upgrading my brakes. now does the abs modulator ever need to be replaced??? i think this can also be called a, r a b s control valve. these things are mounted on the front frame rail way under the brake master. rock auto has it for like 145 bucks. im sure mine is original.
Old Jan 17, 2010 | 03:41 PM
Lazy K's Avatar
Lazy K
The RABS module consists of a spring loaded dump chamber and two solenoid operated valves. They can go bad but no point in replacing one just for the heck of it.
Old Jan 17, 2010 | 03:46 PM
drewdole's Avatar
drewdole
abs module
could it cause your back brakes to be slow to release if it was bad
Old Jan 17, 2010 | 03:49 PM
87crewdually's Avatar
87crewdually
If this is a problem your having I'd suspect the rubber brake hose first. The inner lining can split and act as a checkvalve not allowing the fluid to release back.
Old Jan 17, 2010 | 03:53 PM
Lazy K's Avatar
Lazy K
I agree with 87. the rubber brake hose is a good suspect. But to answer your question, yes it is possible.
Old Jan 17, 2010 | 04:16 PM
drewdole's Avatar
drewdole
i ve changed everything the back rubber brake hose, the back steel lines, new master, new booster, new wheel clyinders. but i ve never changed the abs module. sometimes it does seem like the back brakes are slow to release, like after a hard quick stop.
Old Jan 17, 2010 | 07:10 PM
David85's Avatar
David85
Are you feeling a bit of a drag, then a "clunk" release of the rear brake?
Does it make any difference between forward or reverse?
