Brakes
Old Dec 8, 1999 | 11:24 AM
Trail_Rider's Avatar
Trail_Rider
Brakes
I've converted my '72 F100 to disks from a '73 F250, using all components off of the '73. After having done this I've looked at newer '94-'96 and have a question on the brake plumbing. The fronts instead of going through any kind of proportioning valve simply "T" near the left wheel and run to both sides. The rears do go through a proportioning valve of sorts but it looks more like an ABS control valve. My question is can I bypass the proportioning valve for the fronts? The newer setup reminds me what I envision an aftermarket proportioning valve setup to be.
Trail Rider
Old Dec 8, 1999 | 11:28 AM
Trail_Rider
Brakes
Old Dec 8, 1999 | 12:39 PM
Phillip Guidry's Avatar
Phillip Guidry
Brakes
Be careful in thinking here, the p-valves should be mounted directly to the port at the master cylinder if in fact there is no p-valve mounted externally.
Phillip
Old Dec 8, 1999 | 01:39 PM
jowilker's Avatar
jowilker
Brakes
TR, I'm getting in the corner with Phil, Tis interesting what you are doing, but the brakes on the newer truck, may be fed entirely different. I suggest that you stay with the system that you harvested from.
The brakes that you apply, could save your life.
John
In the cool still hours of the night, you can hear chevys rusting
Old Dec 8, 1999 | 07:41 PM
Trail_Rider
Brakes
Good point gent's hadn't even thought of it from that point of view. Thanks
Trail Rider
raven3
Jan 2, 2015 12:07 AM
alchemist1
Nov 11, 2012 12:11 PM
YZ250rider
May 4, 2012 05:26 PM
RedBandit
Apr 13, 2008 06:17 AM
ferguson777
33
Jul 18, 2006 01:53 PM
