Egr
Old Jan 17, 2010 | 09:18 AM
TurnerBioDiesel's Avatar
TurnerBioDiesel
Egr
Hello.
I have another Question. The egr delete. I know there is the unplug option, But what is this egr delete kit you can buy. Since I have to do head gaskets im just searching options i can do . Should I just unplug, or is it better to do the hole kit thing. Catalog - Ford 6.0L EGR Cooler Delete
Old Jan 17, 2010 | 09:41 AM
tex25025's Avatar
tex25025
Originally Posted by TurnerBioDiesel
Hello.
I would actully suggest against just unplugging it. If that's all your are going to do then just have it turned off via a tuner as some models have it to where it throws a CEL if the EGR is just unplugged.
The two other viable options are EGR Bypass or the entire EGR Delete.
I opted for the Bypass and have not had any issues with it at all. As long as you go to someone that knows how to weld it shut(and you have to be a little careful with it as it is a weaker metal and will crack fairly easily), it'll do right by you. Also, I don't know if emissions are something to be considering either now or in the future while you still own this particular vehicle, but if it is, this will also help you pass a visual inspection(that's if they know what to look for).
TheDuke
Feb 5, 2014 09:50 PM
MtnGoat
Jul 5, 2013 11:39 AM
LKCKR
Sep 6, 2011 10:40 PM
bkvanbek
Jan 10, 2009 12:27 AM
