More AIC ?'s
Old Jan 16, 2010 | 10:29 PM
Oversize's Avatar
Oversize
More AIC ?'s
Ok I got the AIC from the guy at work and found the connector for it and it works fine, now I dont have the mounting bracket for it, So Im not sure what its supposed to look like to try to fab one, especially due to the weight of the module itself. So does either anybody have a spare bracket or pictures of the one I need so I know what it looks like real well so I can fab one up? Im not entirely sure where the factory mounting was intended on the OBS as the one I have had pictures of the SD dash instead but bo good pictures of the bracket either way. Im hoping to put it under the dash right in front of the tcase shifter.
Old Jan 17, 2010 | 07:02 AM
yoslick's Avatar
yoslick
I've seen em mounted right to the left of the ODB2 port, if you look theres a couple screw holes there, unit mounts to a flat plate with a tab that mounts to these holes, my truck has carpet so I just laid it right next to the 4x4 shifter and it's settled into the carpet nicely, easy to read and operate and hasn't moved yet.
Old Jan 17, 2010 | 08:24 AM
Hussler's Avatar
Hussler
PM superduty4X4.
He might still have the bracket designed for OBS.
https://www.ford-trucks.com/forums/8...t-for-aic.html
superduty4x4
15
Sep 6, 2021 10:50 PM
MPlayer
Nov 3, 2011 11:11 PM
superduty4x4
Apr 7, 2009 02:55 PM
