clunking noise while driving
Old Jan 16, 2010 | 02:13 PM
peewee420's Avatar
peewee420
there is a clunking noise coming from the front end of my 77 f-250 i cant figure it out when im driving it starts it keeps making the noise untill i apply my brake and then it stops but as soon as i let off the brake it starts again it doesnt matter how light or hard i hit the brake pedal it stops then starts again please help its driving me insane
Old Jan 16, 2010 | 03:56 PM
fordtech08's Avatar
fordtech08
sounds like your pads are moving around have you recently had brakes done? you should check them out asap
Old Jan 16, 2010 | 04:03 PM
starmilt's Avatar
starmilt
The whole caliper is moving you need to fix it pretty quick before it damages the mount.
It is easy and cheap to do.
Old Jan 16, 2010 | 04:20 PM
peewee420's Avatar
peewee420
i did the breaks about two months ago the hex bolt that holds the pads in place snapped so i welded it in place do you know anywhere i can buy one of those hex bolts. thank you for your help
Old Jan 16, 2010 | 04:24 PM
peewee420's Avatar
peewee420
im also having a problem with getting the rear drums off the truck the drums are in pretty bad shape i tried the hammer method and the drums started to break off on the edges it appears their is a hub of some sort probaly for the axle that looks to be part of the drum they need to be done and i dont wanna pay alot of money to have someone else do it
Old Jan 16, 2010 | 04:33 PM
fordtech08's Avatar
fordtech08
the drum and hub are two different pieces, have you backed the shoes off yet, also did you try hitting the drum into the truck, it helps break the rust free
Old Jan 16, 2010 | 05:35 PM
starmilt's Avatar
starmilt
Peewee napa used to have those bolts also the slide and spring.
Old Jan 16, 2010 | 06:18 PM
peewee420's Avatar
peewee420
Talking
thanks for the help
Old Jan 16, 2010 | 07:31 PM
peewee420's Avatar
peewee420
i tried to back the shoes off but when i try i cant find any adjuster screw i turn the back wheel as much as i can but no luck it does seem its one piece i scraped some of the paint off the hub and i couldnt see a space it looks solidwhen i pry it it looks like its stuck in the middle where the hub is
Old Jan 16, 2010 | 07:41 PM
fordtech08's Avatar
fordtech08
pb blaster is going to be your new best friend
Old Jan 16, 2010 | 07:57 PM
starmilt's Avatar
starmilt
Pb blaster and a little propane torch. I'm not sure on yours but there were some that you had to pull the hub. some of the older ones in the 60's had 3 little screws holding it on.
Old Jan 17, 2010 | 10:06 AM
peewee420's Avatar
peewee420
whats is the name of the bolt that holds the pads in place i dont think my calipers moving its not loose
craigh5100
Dec 27, 2019 12:21 PM
barrglas
Dec 17, 2016 02:53 PM
7.3lpowerstroke
Oct 22, 2011 01:00 PM
jd1083
Aug 7, 2011 09:27 PM
Blafferty
General Automotive Discussion
Nov 30, 2009 01:15 PM
