1978 - 1996 Big Bronco
plugs & wires
Old Jan 16, 2010 | 02:55 AM
beermonger's Avatar
beermonger
plugs & wires
put new plugs & wires in today, truck idles better than I ever seen it, but under load it starts to miss at around 2000 RPM's
and no, I don't have a lot of money, so yes, I used Xact wires and autolite plugs (copper core)
Old Jan 16, 2010 | 06:15 AM
b4hntn's Avatar
b4hntn
Depending on your firing order, the two wires that fire right after each other need to be away from each other in the weiring loom. On my 351 5-6 on a 302 7-8 but check your firing order to see yours.
Old Jan 16, 2010 | 05:27 PM
mprice's Avatar
mprice
did you do the timing as well?
btw, autolite copper plugs are considered to be the second best choice, just behind motorcraft. autolite makes both but there is speculation that the ones that say motorcraft on the side are made to slightly higher spec. anyway, nothing to apologize for.
Old Jan 16, 2010 | 10:42 PM
beermonger's Avatar
beermonger
timing is right where I want it.
on the next trip, the engine missed at 3000 Rev's
now, I can't get it to miss at all.
Old Jan 16, 2010 | 11:27 PM
greystreak92's Avatar
greystreak92
I am going to assume the truck in question is the '87 in your gallery. (I would suggest putting the truck info in your signature so when the questions come up we know what year, engine, transmission, etc. you are working with.)
Base timing on truck's equipped should be within about 2 degrees of the timing listed on the catalyst decal under the hood. If you don't set timing according to the under-hood instructions the computer can't adjust properly during normal operation. This leads to premature plug failure and poor fuel mileage and performance.
Base timing is typically 8-10 degrees BTDC but I know guys run as high as 12 BTDC for performance sake. Don't take these numbers as gospel. Check the under-hood info and oly adjust base timing with the truck at normal operating temp.
Old Jan 16, 2010 | 11:55 PM
beermonger's Avatar
beermonger
ok ok, I'm an idiot, I dont know how to make a signature thing.
I also didn't know my truck has a computer, I wouldn't think a 4bbl needed one, and I'm not sure about the tranny, but I think a C6.
whatever the spark thing was, it figured itself out,
now for the back FIRE ing, the MPG's and of course the rear window
Thanks for the help guys
Old Jan 17, 2010 | 01:20 PM
Kemicalburns's Avatar
Kemicalburns
go into the user cp to setup your signature. use this area to give a discription of your vehicle. engine,tranny, tires, gears and any other mods you may have.
I am not familar with that brand of spark plug wire your using. ford 9mm wires work very well in my opinion. like mentioned make sure the wires are routed properly and not touching or crossing on cyl 7&8. what did you gap your plugs to?
Old Jan 18, 2010 | 12:50 AM
beermonger's Avatar
beermonger
Now I see why I don't have a signature; it says I need to make 25 posts in order to enable it.
Anyways, wires were routed exactly as the old set, (never had a problem before)
Gapped the plugs at .44 She seems to have settled down with the missing,
but still has a tendancy to backfire when letting off the throttle at highway speeds.
flames not near as big at they were. (only saw the reflection of them tonight)
87 Bronco (351W - 4bbl) all I have for an exaust is a flowmaster thar dumps out right behind the pass. seat area
Old Jan 18, 2010 | 02:38 AM
greystreak92
If its an 87 its one of the very last carb'd Bronco's or its been swapped. Sorry, I assumed that being an 87 it would have been EFI since the vast majority are.
Old Jan 18, 2010 | 03:01 AM
beermonger's Avatar
beermonger
I suspected a dead cylinder. pulling the plugs, the one cloest to the glovebox did smell of gas. I thought that would solve the backfiring thing, but not so much.
I noticed a slightly higher speed at a given RPM, so I'm guessing she is firing on all 8. The exaust doesn't smell near as rich as it did. and she doesn't bog down on the uphill as bad as she did
Old Jan 18, 2010 | 11:03 PM
Kemicalburns
the 5.8 didnt see efi till 88 model year for broncos or f150 etc...
If your having backfiring issues i would suspect 2 things. Make sure your timing is spot on with a light. you might also consider a carb rebuild or locate a good carb tuning mechanic.
that year is a great combo.
Old Jan 19, 2010 | 01:29 AM
Encho's Avatar
Encho
The Southernmost Mod
He can't make a sig. until he has at least 25 posts Kem.
Old Jan 19, 2010 | 02:33 AM
beermonger's Avatar
beermonger
carb rebuild is soon on the list (I bet the power valve is shot)
timing should be fine, but will be re checked in the morning.
many vaccume lines are off, and that will be addressed as well in the morning
87 Bronco (351W - 4bbl) all I have for an exaust is a flowmaster that dumps out right behind the pass. seat area
Last edited by beermonger; Jan 19, 2010 at 02:42 AM. Reason: Michael Jacksons death
wells2
All Things Towing
Aug 12, 2011 08:12 PM
bashby
Dec 12, 2010 09:41 AM
berry1234
Mar 19, 2010 06:47 PM
seamonkey49
Escape & Escape Hybrid
Jun 7, 2007 07:38 PM
JimMorrison
Dec 1, 2004 06:33 AM
