so please help a out again. i have already figured out that i should throw the stock downpipe out. for this reason am i in contact with tymar. so what more? wich other mods are in your opinions recommended to get a reliable truck with a good fuel mileage?
I would do a 6637 air filter. Then do some gauges and then contact your tuner of choice and throw a chip in it. DP-Tuner, Tony Wildman, or Power Hungry Performance are the big three on here. But there are a bunch of other smaller companies that do a really good job tuning. That should get you the best bang for the buck and the best fuel economy and power for a reasonable price
I also recommend the 140v mod and check the fuel pressure at the schraeder valve. You want between 60 and 80PSI. If it is lower than that, shim the FPR.
You can leave the cat in. It is not that restrictive and it will make the exhaust a little quieter.
i have already deleted the muffler, it's all too quiet imo
i dont know most of the acronyms by now, sorry. what means 140v ??? it sucks sometimes to be a rookie
