MotorCraft Oil
Rog
I have just under 200 k on my Mark VIII and still use 5W20 and it uses no oil between changes. I would recommend using the oil that your manual says to use, either synthetic or petrol. unless you have way more miles and a lot of wear on your engine.
What is your source of information on using 5W20 in the 4.0 Even Ford recommends against using 5W20. They told me that it was a No, no in the 4.0, it needs 5W30.
Rog
It's not Motorcraft but figured I'd give you guys a heads up on it.
5W20 in engines calling for 5W30 - Bob Is The Oil Guy (3 pages long)
Rog
On the other hand here is a section of the Ford specs from one of the posts that say the 4.0 engine needs the 5W-30 weight oil...
NOTE: THE "EXCEPTION 2001-2002 VEHICLES" SHOULD BE SERVICED WITH SAE
5W-30 MOTOR OIL.
Exception 2001 Vehicles
Engine Vehicle
3.3L Villager
3.9L Lincoln LS
4.0L Ranger, Explorer/Mountaineer, Explorer Sport, and Explorer Sport
Trac
Exception 2002 Vehicles
Engine Vehicle
2.0L HP Zetec SVT Focus
3.3L Villager
Trac
I agree with everything that you have posted. Even if there has been a changing of the Ford Guru minds that 5W20 is now an acceptable oil in place of the 5W30 I personally fail to see the benefit in changing unless you are located in super sub-zero temps. That and the fact that the 5W20 comes in 5Qt jugs. IMHO.
Rog
In Fords oil TSB 02-1-9, it excludes both the pushrod & OHC 4.0L from using the 5W-20 lube. https://www.ford-trucks.com/tsb/full...php?tsb=02-1-9
The problem is that the 4.0L never got an oil pump upgrade that allows it to be able to produce the needed flow, of the lower viscosity 5w-20 at the engines operating temp.
So the problem isn't with cold start up pumping/supply, it's with the pump not being able to produce enough flow with the 20 weight at hot operating temps.
Not saying our 4.0L engines are going to come unraveled if we use 5W-20, but over time & or under load, were likely to have problems, or Ford wouldn't have Excluded the 4.0L from using the 5W-20.
It's our engine, so we can pour in what ever we want, but I'm staying with 5w-30 in my 4.0L as Ford suggests!!!!
02-1-9***ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
<TABLE cellSpacing=0 cellPadding=3 width="96%" border=3 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD align=middle width="25%" bg*************** itxtvisited="1">TSB
02-1-9
</TD><TD align=left width="65%" bg*************** itxtvisited="1">
- ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE <NOBR id=itxt_nobr_2_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">FUEL
</NOBR> VEHICLES ONLY
<TABLE border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD width=230 itxtvisited="1">FORD:
</TD><TD itxtvisited="1">1992-2002 CROWN VICTORIA
1993-1994 TEMPO
1993-1997 THUNDERBIRD
1993-2002 ESCORT, MUSTANG, TAURUS
1995-2000 CONTOUR
1998-2002 ESCORT ZX2
2000-2002 FOCUS
1993-1996 BRONCO
1993-1997 AEROSTAR
1993-2002 E SERIES, F-150, RANGER
1995-2002 WINDSTAR
1997-1999 F-250 LD
1997-2001 EXPLORER
1997-2002 EXPEDITION
1999-2002 SUPER DUTY F SERIES, SUPER DUTY F-53 STRIPPED CHAS.
2000-2002 EXCURSION
2001-2002 ESCAPE</TD></TR><TR itxtvisited="1"><TD width=230 itxtvisited="1">LINCOLN:
</TD><TD itxtvisited="1">1991-2002 TOWN <NOBR id=itxt_nobr_22_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">CAR
</NOBR>1993-1998 MARK VIII
1993-2002 CONTINENTAL
2000-2002 LS
1998-2002 NAVIGATOR</TD></TR><TR itxtvisited="1"><TD width=230 itxtvisited="1">MERCURY:
</TD><TD itxtvisited="1">1992-2002 GRAND <NOBR id=itxt_nobr_28_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">MARQUIS
</NOBR>1993-1994 TOPAZ
1993-1997 COUGAR
1993-1999 TRACER
1993-2002 SABLE
1995-2000 MYSTIQUE
1999-2002 COUGAR
1997-2001 MOUNTAINEER</TD></TR></TBODY></TABLE>
This article is being republished in its entirety to update the vehicle models, engines and years affected.
<TABLE border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD width=80 itxtvisited="1">NOTE:</TD><TD itxtvisited="1">PLEASE REFER TO THE VEHICLE APPLICATION LIST LATER IN THIS TSB FOR A COMPLETE LIST OF VEHICLES AFFECTED BY THIS TSB.</TD></TR></TBODY></TABLE>
ISSUE:
Ford Motor Company now recommends SAE 5W-20 viscosity grade for servicing most gasoline and flexible fueled vehicles.
ACTION:
All 2001 and 2002 vehicles where SAE 5W-20 is specified should be serviced at the recommended oil change intervals using SAE 5W-20. This oil is an improved formulation to improve fuel economy. Testing has validated this viscosity grade can be used in many previous model year vehicles. It is recommended ALL vehicles on the following Vehicle Application Listing be service with SAE 5W-20.
All 2001-2002 vehicles other than those listed in the "Exception 2001 Vehicles" or "Exception 2002 Vehicles" chart are being filled with SAE 5W-20 motor oil at the factory and should also be serviced with SAE 5W-20 oil. Vehicle Application Listing Approved For SAE 5W-20 Motor Oil
<TABLE border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD width=80 itxtvisited="1">NOTE:</TD><TD itxtvisited="1">THE "EXCEPTION 2001-2002 VEHICLES" SHOULD BE SERVICED WITH SAE 5W-30 MOTOR OIL.</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TH vAlign=bottom align=middle itxtvisited="1">Engine</TH><TH vAlign=bottom align=middle itxtvisited="1">Vehicle</TH></TR><TR itxtvisited="1"><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">3.3L</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">Villager</TD></TR><TR itxtvisited="1"><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">3.9L</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">Lincoln LS</TD></TR><TR itxtvisited="1"><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">4.0L</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">Ranger, Explorer/Mountaineer, Explorer Sport, and Explorer Sport Trac</TD></TR></TBODY></TABLE>Exception 2002 Vehicles
<TABLE cellSpacing=0 cellPadding=3 border=1 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TH vAlign=bottom align=middle itxtvisited="1">Engine</TH><TH vAlign=bottom align=middle itxtvisited="1">Vehicle</TH></TR><TR itxtvisited="1"><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">2.0L HP Zetec</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">SVT Focus</TD></TR><TR itxtvisited="1"><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">3.3L</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">Villager</TD></TR><TR itxtvisited="1"><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">4.0L</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left itxtvisited="1">Ranger, Explorer/Mountaineer, Explorer Sport, and Explorer Sport Trac</TD></TR></TBODY></TABLE>
<TABLE border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD width=80 itxtvisited="1">NOTE:</TD><TD itxtvisited="1">IF VEHICLE IS NOT LISTED IN THIS APPLICATION, SAE 5W-30 OIL IS RECOMMENDED. REFER TO TSB 99-8-16.</TD></TR></TBODY></TABLE>
