Idle time spent productively
Pulled the intake manifold, and throttle body off the 5.0 yesterday.
I was looking for vacuum leaks, found that I hadn't put vacuum to the PCV so that helped. Routed all vacuum lines and replaced gaskets and re-installed intake.
Fired the beast and it ran smoother; still idled high , which I found to be my linkage being too short and doesn't allow throttle to relax to idle. Will have to redo throttle linkage in the spring, which I was going to do anyway.
May have coolant fluid leakage, which seems near the water pump.
My project for today, while our above zero temps last !
Fired up and ran the length of the driveway
Well I started the beast again today; no noticeable leaks on the coolant.
Actually pulled the truck in and out of the garage under its' own power !
Will take battery out again this weekend; for winter. Now working on window glass in vent frames; and side window and dividing posts.
More to come.
Later
Tom
More to come.
Later
Tom
I applaud your motivation and progress! As mild as our winters are here, compared to yours, it takes me a lot of self-motivation to go out to the garage at all. Once I get there, I'm fine. I can imagine what it's like up there! But the more work you do now means the sooner your truck will be ready to drive when it's nice out!
