Driveshaft bolt removal
Old Jan 15, 2010 | 10:24 AM
mqford's Avatar
mqford
97 4.2 manual. Trying to get driveshaft off to drop tranny. The bolts are really stuck. Not particularly rusted, but putting PB Blaster on them nonetheless. Have tried long-handled half-inch ratchet to the point I am afraid I will twist one off.
These things are not reverse threaded for some reason are they?
Anybody else had the same problem and come up with a trick to break them loose?
All I have are normal hand tools, so no air impacts or acetylene torches...
Thanks!
Old Jan 16, 2010 | 11:57 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
Try a 12 point closed end wrench with a cheater bar.BTW,don't forget to mark the driveshaft flange with the differential flange before removing it.
Old Jan 16, 2010 | 09:47 PM
mqford's Avatar
mqford
Thanks BlueOval,
I got a hold of a 3/8 flex handle that allowed me to put wrench to socket right on the bolt with out any swivels and such and made myself a cheater pipe that I could manage under there. Heated them with a propane torch and finally managed to get two of them lose so far -- started raining today so have not tried the other two. Had not had a chance to get back on here until now.
Those bolts have a 70-95 ft-lb torque spec and are very stiff... Would you recommend replacing them when I put back on? Not sure if the amount of heat I applied would be enough to change the temper or not -- just a Burnz-o-matic thing.
Does not matter how it goes back into the tranny does it? Just want to match up the bolted end to its original position, right?
Thanks..
Daniels54
Jul 30, 2016 11:02 PM
anthonym92
16
Jul 21, 2016 10:08 PM
Salsa91
15
Jun 10, 2015 11:10 PM
crushtheogre
Feb 11, 2012 08:24 PM
DutchB100
Jan 14, 2012 08:15 PM
