HPOP Housing worn
Old Jan 15, 2010 | 08:14 AM
formula joe's Avatar
formula joe
HPOP Housing worn
First of all I have read a lot of very good information on this forum and now I need some. I was wondering if anyone has had this problem before? I found the HPOP housing is worn where the hoses fittings go and now we are looking for a new replacement pump. Is there a way to retap these or am I out of luck?
Old Jan 15, 2010 | 08:26 AM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE...
are the threads warn or are the orings going bad??? what makes you think there worn??
Old Jan 15, 2010 | 09:09 AM
formula joe
it looks like it had issues before and they just screwed it in and it held but now that we took it off you can see the threads almost gone on one side.
Old Jan 15, 2010 | 10:22 AM
ron's power stroke
i think your out of luck...there is up to 3000 PSI in that pump..it needs to be leak proof..i dont think there is another fitting like that one to retap for..looks like you will be looking for a new pump...
Old Jan 15, 2010 | 10:26 AM
formula joe
that's what I thought. Thanks for your help.
Old Jan 15, 2010 | 10:28 AM
big poppa's Avatar
big poppa
Found this if this helps, Guzzle has a retapping tool and related o-rings, take a look Replacement O-rings for Ford Diesel Engines
