Mounting a Pre-pump filter (BF1212)
I want to mount this pre pump on my frame rail.
I was wondering if anyone had some good pics of how they mounted it.
Can I drill 3 holes in the frame and mount it?
I have seen it welded to the frame. I just don't want to cause damage to the frame.
Thanks alot for the help guys.
http://www.itpdiesel.com/other/FuelS...Kit-Manual.pdf
http://www.fleetfilter.com/shop/item...emid=892&catid
Not the ITP one.. It side mounts.
I am gonna get a piece of steel and bend it in an upside down U shape and bolt it up and lock tite it
I know that lots of Cummins systems use this same element just north of the tank, but I don't know if the fuel pump on the Didge Cummins is inside the tank ahead of this element.
The most typical approach on our PSD's is a 10-20 micron filter element ahead of the pump (if any), followed by the 2 micron rated element that can be located either down on the rail at the pump when eliminating the fuel bowl or relying on the stock fuel filter in the valley that is also rated at about 2 micron.
I'm not saying this 2 micron filter won't work... but I would be very cautious about putting something that tight on the suction side of my pump. he only thing that would make me more comfortable with this concept would be having some flow ratings data showing that the 2 micron setup will flow enough fuel at very low pressures so as to not starve the pump, and it would need to be really large to have enough surface area for that, too.
I'm glad you posted. I was gonna send you a PM this week cuz I washed my cover again and I love it!!
Here are the specs on this 2 micron filter.
Part Number: 33528
UPC Number: 765809335288
Principal Application: Cat Engines + Equipment (2 Micron) - (6 Micron version is 33352)
All Applications
Style: Spin-On Fuel Filter
Service: Fuel
Height: 7.007
Outer Diameter Top: 3.713
Outer Diameter Bottom: Closed
Thread Size: 1-14
By-Pass Valve Setting-PSI: NONE
Max Flow Rate: 12-15 GPM
Nominal Micron Rating: 2
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.715 2.430 0.250
I am already running an inline filter pre-pump. Would I be better off mounting this post pump for now and adding a bf1212 filter pre-pump in the future?
I looked over the BF1212 specs, and listed the info below for reference.
Fuel Filter Specs (BF1212):
Flow Capability: 210gph @ 1psid / >300gph @ 3psid (the "d" in "psid" is for DIFFERENTIAL pressure across the element)
Filtration: 86% Efficient @ 4 micron / 99% Efficient @ 20 micron
Water Removal: 93% @ 60gph / 87% @ 120gph (based on 2500ppm free water injection)
(emulsified water removal will be approximately 3-5% less)
Burst Pressure: 150psi
Collapse Pressure: 100psid
Cross-referenced alternative elements for the BF1212 that fits the Baldwin fuel filter head.
- Baldwin BF1212
- Donaldson P55-8020
- Fleetguard FS1212
- Fram PS3712
- Luberfiner LFF8020
- WIX 3340
Now to your questions and in reference to the specs you posted on the Napa element.
The Napa element's flow rating appears to be plentiful, but again, there is no differential pressure identified for that corresponding flow rate. In other words, if those flow rates are for the kinds of differential pressures that you find on the pump's discharge, then the flow rate you will get at the lower suction side differentials (1-3 psid range) will be much, much less than the listed rate of 12-15 gpm.
Again, not knowing what differential pressures were used for the 12-15 gpm Napa flow rates, it just leaves the question begging and I can't make a knkowledgeable call on it. The only reason I even questioned it is beacuse I have not seen a suction side element rated so low before... not that they could certainly be out there.
That said, I would try to find out those pressure ratings for the Napa unit before deciding which location it would work best in. If it is more suited ofr pump discharge pressures, then by isntalling it on the frame rail near the pump, you gain the flexibility of being able to do your own fuel bowl delete and eliminate the existing OEM fuel filter in the valley.
Looks like you've already done some good investigation thus far, but just need a few more specs to know the best path forward.
Question for you...
If you're already running an inline filter ahead of the pump, why change? I've been running the ITP kit with the BF1212 for over two years now and have had zero problems with it. Personally, as I look forward to bringing my mods over to my 7.3L Excursion bit-by-bit, I plan to go with a clear bowl Racor unit next time on the pump suction so I can take a quick glance for the presence of water without necessarily having to drain the filter element. Aside from that goal, I would use the BF1212 again for that same application. However, if what you have is working well, why change? There are a number of guys running the small inline filters with no trouble, and they are a little cheaper than the Baldwin's.
BTW... it's always good to hear about continued satisfaction with the covers. Thanks for that.
YEP! What he said! Brian from BTS said I should go back to a 30 micron (which I did) from the 10 micron I had pre-pump because of the possibility of over working the fuel pump.
I found a spot under the drivers floor board and behind the flinder well to put it.
I'll show you on fri when you stop by.
I got the head and get filters from Tractor Supply Company.
100_0364
100_0363
100_0362
Here is mine
Filter is a Wix 33405 10 Micron filter.
I am very happy with it.
I plan on a 2 micron post pump filter this summer
Something else. Filters cause restriction. Adding another filter ON TOP OF the tank filter might cause more restriction than you desire.
