Stalling Problem
Old Jan 15, 2010 | 08:06 AM
rocketfootballer's Avatar
rocketfootballer
Stalling Problem
My 94 f-150 4x4 with a 4.9L and a 5-speed stalls going down the road at anything over 7 mph. It also has very little power unless you are into the throttle, used to be able to start out in 2nd gear without any throttle, now it tries to stall out in first and has a very stumbly idle. Coil is less than a year old, fuel pump and filter are both less than a year old also. Maybe IAC and plugs and wires??
Old Jan 15, 2010 | 10:54 AM
gtrosema's Avatar
gtrosema
check for codes? Throttle position sensor, fuel pressure regualtor, map sensor?
