Regular to Synthetic
Slim
I also have the bypass filter, and IMO it's not worth going to synthetic if you don't do the bypass, too.
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
But, high lead on the sample doesn't mean its the oils fault.
I'm sure there are other factors in there as well.
The bypass helps clean the oil, synth or dino.
They are good either way IMO.
Unless you are doing 3k oil changes, i'd be running some home brew bypass system with a cheep napa filter.
Pluss like previous discussions. You dont get full benifits first change.
I dont think i'd run 10k on my first synth change. To many other things left over.
They say the detergants are the same, which could be, but synth is a bit smaller.
I think it gets in and roots out some sludge that dino oil doesn't. Then this stuff goes mixing around in there, and the bypass wont pick it all up. cause it only does a percentage 10-20% oil per pass around, which eventually it will catch all, but its a bypass, it goes there on free will sorta deal.
So, jim's high lead reading coulda been from old oil from Previous oil changes, that never came out.
Pluss think of all the oil sitting in the engine, hpop and stuff you can't get out.
The only way you could get allt hat out is to flush with some sorta thing like keroseane, (sorry not doing that one) or to go a short OCI on synthetic to help get the rest out.
I am brave enough to pull the relays and the fuses to stop it from firing, and turn it over after my first Synth run at 3-5k miles and try and pump the oil rails out and whatever is left.
I'm personally trying to come up with a bypass system that will work for me that will allow a higher amount of fluid in the system, which will increase your life span of the oil, more oil is harder to break down sorta idea.
And if i change the bypass filters, then i'll have almost 3qt's or more to add to the engine.
I'll have a huge write up on all of this sometime next month when I do go all though with it.
I am going to talk to some others on synth to dino relations and stuff, and why one is better than the other, this info will be included in there as well.
I'd hate to tell people to put it on hold.
but, my personal thought at the moment is, snyth will not cover up your leak problems, but tell you where your weakpoints are by leaking there.
If you need new IPR nut and o-rings, or your turbo has a slight leak you never seen, or need new oil pan. yada yada.
I'm scared on the oil pan one, my seaps a bit.
Might just need a tighten up.
That, or i'll cut the cross member like others have suggested. (yea, i'ma call you on that one travis)
When I do a filter change, the oil I'll have to add back will help keep viscosity up and get some more additives back in the oil.
and how its heat cycled.
The heui is harsh on lubes.
The IH T444E holds 20% more oil than the PSD.
The IH spec is 10K on dino with no bypass filter.
Bill
Don't cut the crossmember. It is there for a reason and you will regret it later.
Yea. I understand what you guys talkin about.
Thats why with bypass I'm trying to get most total oil increase I can to help with that.
I have a few before samples here i've taken, and i'll need blackstone to send me like 4 kits for oil analisis. And then I'll start testing often on the truck after new setup.
Looking like it will cost me around 350 unless i can find them cheeper.
This was my first time using synthetic and everyone told me the first oil change would be cut short. I sent the sample in at 10k miles and it came back with almost 5 times the normal lead content. They said high lead means bearing wear, but with all other paramters well below spec, they said it's probably something else that tainted the oil and just change the oil and test again in a little bit.
But I've worked on enough injectors that ran synthetic (it's easy to tell and I ask the customer about it) to make me want to give it a shot. Even extended oil changes with synthetics the injectors are always in better shape than regular oil with normal changes. Thought I'd try it for myself, so we'll see....
inj. Also believe (results not complete yet) that the heui inj system
perfers 30wt oil. As of now we have 120k on a set of inj's with 30wt oil.
A quick test of the poppets show .0035 to .003
The inj's are oem ab splits (uncoated).
This truck also has alot of idle time on it.
I should have put and hr clock on it but never got around to it.
.02
Bill
