351M ????
Old Jan 14, 2010 | 10:36 PM
Bearkat50's Avatar
Bearkat50
351M ????
hello guys, can you please help me in trying to figure out what i need to do make a 351M motor fit in my 82 full size bronco that originally came with a 302 and automatic? is there any adapter plate? what has to be done to make it work in this truck if it is at all possible?? if its not possible please let me know thanks
Old Jan 15, 2010 | 01:31 AM
ozstang65's Avatar
ozstang65
Simple answer, don't bother.
M series were big block bellhousings so you'd have to find a gearbox to suit. Horrible economy, extremely heavy block for a 351.
Old Jan 15, 2010 | 09:23 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Check out Jeff"s bronco graveyard Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale and I think a company called L and L L&L Products IF you are pushing hard to do this swap. I think I have seen kits there for such a swap.
Old Jan 15, 2010 | 10:43 AM
Franklin2's Avatar
Franklin2
No kit needed, these engines came in these body styles originally in at least 1980 and 1981, and maybe a year or two more before they got rid of them. So if you get a older truck with a 400 or 351m, you should have the parts to bolt it in, including the tranny which you will need.
If you have a free engine and that's the reason for trying to install it, having to buy a whole other tranny to make it fit sort of lessens the "free" aspects a little bit, unless your tranny is shot already.
