1978 - 1996 Big Bronco
can this work??????
Old Jan 19, 2010 | 12:43 PM
American Thunder's Avatar
American Thunder
It wasn't less nickel content that made the newer blocks weaker. Sometime between 1980 and 1981, Ford redesigned the 302 block to be much lighter.(and of course, cheaper) I assume it was to improve the new Fox body's balance and handling. If I recall, the newer 302 ( 5.0 ) block lost about 40 lbs compared to the older 302 blocks, and most of the lost material came from the main bearing support webbing. Even so, the post '80 blocks can still handle 400 hp or so, without much risk.
The Mexican 302 blocks you mentioned are quite a bit stronger, and do contain more nickel, since they're built to deal with the poor fuel and detonation conditions encountered in Mexico.
American Thunder
Double post.. again.
Old Jan 19, 2010 | 04:54 PM
Kemicalburns's Avatar
Kemicalburns
the 400 can be a good motor if you drop some money into it. out of the box its a POS boat anchor.
the 400 needs excessive head work, increasing the compression to almost 10-1, upgrading the cam and intake/carb.
Old Jan 20, 2010 | 07:23 AM
American Thunder
And then after all that messing around with the 400, you end up with a motor that's prone to cracking the heads. Like I said though, If you're swapping to the 351M/400 mounts and transmission, a bone stock 460 is the ticket. I think the 460 will get better mileage even.
p.s. The 400 does make a pretty good boat anchor. As long as you have a good strong winch.
American Thunder
Double post.
Old Jan 20, 2010 | 10:39 AM
Broncoholic1's Avatar
Broncoholic1
If that is the case All ford heads need excessive head work.
Out of the box most late engines need work.
Oh My 429 DOOE-R's are ok I guess.
All smog bumps have to be removed for proper flow.
Little bowl blending = Good To Go...
Old Jan 26, 2010 | 07:24 AM
oneill300's Avatar
oneill300
either way, best of luck with it!
BroncoMonster82
Jul 2, 2012 08:00 PM
bigbeise
Jan 23, 2008 04:26 PM
bfensler
Oct 25, 2004 01:28 AM
rdnjr
Oct 21, 2003 04:47 PM
msautry
Nov 18, 2002 07:43 PM
