i really do need help
Old Jan 14, 2010 | 08:19 PM
88 ford's Avatar
88 ford
ok i have an 88 ford f150 single cab 302 i am replacing the harmonic balancer and stuck in a rut i can not get the center bolt out of the harmonic balancer please help me
Old Jan 14, 2010 | 10:26 PM
Fomoko1's Avatar
Fomoko1
Welcome aboard.
Check in the 1987 - 1996 F150 And Larger F-Series Trucks forum: 1987 - 1996 F150 And Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Swing by and say hi in your local Florida Chapter: Florida Chapter - Ford Truck Enthusiasts Forums
Old Jan 14, 2010 | 11:23 PM
FORD RANGER's Avatar
FORD RANGER
its a big bolt find a socket that size and unscrew it.
Old Jan 15, 2010 | 12:02 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.It's great to have you here.
Old Jan 15, 2010 | 01:37 PM
88 ford's Avatar
88 ford
but how do i get it off i tried with a socket and ratchet and it just spun the crank shaft
Old Jan 15, 2010 | 02:42 PM
senix's Avatar
senix
you have to hold the crank...I did it before by the cover, exposing the flwheel. You have to wedge something in the flywheel so you can break the bolt loose.
Old Jan 15, 2010 | 03:20 PM
88 ford's Avatar
88 ford
ok i got the bolt off now how do i get the balancer off i tryed a crow bar to push it off but it doesnt work do i need a tool to get it off or just a little elbow grease
Old Jan 15, 2010 | 03:46 PM
FORD RANGER
you have to A: hold the crank or B: use an impact on the bolt. you have to take the belts and pulley off first. you may have to pull the fan and shroud off to get a 1/2" drive impact in there is thats the best way. or use a big breaker bar and wedge on the frame but thats dangerous. and use the starter to turn the engine over to break it loose. then you need a puller to get the balancer off. again i don't recommend doing the breaker bar. and remember lefty loosey/righty tighty. no offense.
Old Jan 15, 2010 | 03:53 PM
Fomoko1's Avatar
Fomoko1
For help on this and everything else you`ll ever need for truck info post in the 1987 - 1996 F150 And Larger F-Series Trucks forum: 1987 - 1996 F150 And Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Just click on that link I`ve supplied.
Old Jan 15, 2010 | 04:32 PM
FORD RANGER
ok..............
Old Jan 15, 2010 | 04:34 PM
Fomoko1's Avatar
Fomoko1
Thanks for your help Jack!
Old Jan 15, 2010 | 04:48 PM
FORD RANGER
i was trying to help is all.
your welcome.
Old Jan 15, 2010 | 05:37 PM
senix's Avatar
senix
If the balencer does not want to come off then a puller is going to be required. you can usually get one on loan from autozone and other parts stores.
Old Jan 15, 2010 | 06:26 PM
FORD RANGER
scott,
you need a puller no matter what. go ahead and yank on it by hand and your not going to get far! go ahead...
Old Jan 15, 2010 | 06:47 PM
senix's Avatar
senix
scott,
Totally agree, but figured he might as well try...
