1997 Explorer brake problem
Old Jan 14, 2010 | 05:42 PM
sparrky81's Avatar
sparrky81
A buddy of mine has a '97 Explorer, AWD, 5.0L, 178k miles. The thing in any road condition kicks in the ABS for like the last 10 feet when coming to a stop. If that makes any sense. You can hear the module kick in, the pedal goes soft, and the ABS light comes on just as if you were on ice. It's not when you begin braking, but rather when you are almost to a complete stop. He has gone through the brakes. He replaced the Master cylinder and completely bled and changed fluid this weekend. HE thought it might be the master cylinder, I didn't think so. I don't know enough about ABS to be of any use. Does anybody have any suggestions before he takes it to a shop? Money is tight, and we want to avoid a shop bill if we can. Thanks for your time!
Old Jan 14, 2010 | 06:52 PM
scucci's Avatar
scucci
I've heard of this happening when one of the abs speed sensors goes bad due to a front wheel hub having too much wear and excessive play.
Old Jan 14, 2010 | 06:58 PM
sparrky81's Avatar
sparrky81
So we are looking at a hub assy. and front wheel speed sensor? Are there aftermarket parts available, or do I have to go back to Ford? Thanks for the input by the way!
Old Jan 14, 2010 | 09:50 PM
shorod's Avatar
shorod
The rear speed sensors just above the pinion are known common failure points. If you want to possibly save some money, find someone with a scan tool that can access the ABS codes and find out what code is set. The ABS light would not normally come on during ABS activation so it sounds like the ABS system recognizes an issue.
-Rod
dwstenersen
Jan 28, 2017 01:07 PM
5.0 Heaven
Aug 20, 2015 07:21 PM
ttttmaxx
22
Feb 16, 2009 06:29 AM
juggernaut2874
13
Apr 23, 2007 08:32 AM
rhnasko
May 1, 2004 05:19 AM
