Fuel Problems???
Old Dec 18, 1999 | 05:33 PM
Andy's Avatar
Andy
Fuel Problems???
I have a 79 Ford f-150 custom 4x4 and I am led to believe that I have a fuel problem. When running down the road my truck will all of the sudden develop the hiccups, (it seems like it is getting air and then fuel and vice versa through my line, but I checked my line that ran from both front and rear tanks at the carbuerator and it my pump seems to be producing a steady flow of gas. Another thing when both tanks read below half that is when it starts, I tried switching tanks, replacing the fuel pump, even went so far as taking off the waterpump to see if the circular cylinder (eccentric) had been damaged, which it had not been. Does anybody know what it could be? I was wondering if I should just get a kit for my carb and rebuild it, or maybe the floats are sticking, If anybody can help me it would be much appreciated!!!
Old Dec 18, 1999 | 05:51 PM
StockMan's Avatar
StockMan
Fuel Problems???
Your problem may well be the carburetor, but I have seen many ignition problems mask themselves as a fuel condition. What changed when this condition developed? Had you just performed a tune-up or anything significant that you can recall. If you have never had the carb off it may be worth taking it apart to see if there is any crud in there. I am assuming that you have at least one fuel filter in your system if not two. Small stuff does get by and build up over 20 years.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Dec 19, 1999 | 04:16 PM
Trail_Rider's Avatar
Trail_Rider
Fuel Problems???
How about the possibility of water in the tanks? Have you tried fuel conditioner?
Trail Rider
Old Dec 20, 1999 | 07:02 AM
Chuck P.'s Avatar
Chuck P.
Fuel Problems???
Just one other thing to check for-make sure all fuel lines are well away from any heat sources-this will induce vapor lock if they run to close to anything such as exhaust, radiator hoses or the heads themselves. Chuck P.
Old Dec 23, 1999 | 08:51 AM
frankie's Avatar
frankie
Fuel Problems???
Old Dec 24, 1999 | 02:37 PM
bill_1's Avatar
bill_1
Fuel Problems???
check your gas caps?
had prob. with mine, wrong caps
msta999
Oct 5, 2014 01:02 PM
86'F-150
84
Jan 22, 2013 10:33 PM
78 Ford F150 460
17
Jun 24, 2012 11:31 PM
predaina
29
Mar 29, 2011 07:07 PM
Kennebec
Aug 10, 2003 08:54 PM
