Headlight Voltage Drop
Old Jan 13, 2010 | 10:55 PM
bghnkinf250's Avatar
bghnkinf250
I was curious, what do you guys get for voltage at the headlights? I was thinking about adding relays, but measured my voltage and got 13.2v or 13.8v. My lights are bright, but the alternator puts out 14.5. I was wondering if it would make that much of a difference in brightness with an extra 1.3 volts max.
Thanks,
Nick
Old Jan 14, 2010 | 12:29 AM
Crankylove's Avatar
Crankylove
I just picked up some relays to do this same modification. Most of the people I have talked with that have done it, have told me it does make a visable difference in the brightness, and will also decrease the load on the switch, which, in theory, should prolong the life of the headlight switch. I have yet to see the effect in person, but I figure for the $8 in cost in relays and wire, its worth a shot. The next step after the relays, is swapping in some Silverstar headlights when my current lamps burn out.
Old Jan 14, 2010 | 06:22 AM
NavyMIDN08's Avatar
NavyMIDN08
I've picked up the relays, have them pre wired and i'm just waiting to do the work. if you look in the sticky for projects at the top of the forum, under electrical it gives a really good wiring diagram.
Old Jan 14, 2010 | 07:20 AM
JimsRebel's Avatar
JimsRebel
Daniel Stern Lighting Consultancy and Supply
Good info here
Old Jan 14, 2010 | 08:04 AM
bashby's Avatar
bashby
when its dark out, turn the headlights on and run another wire (doesnt have to be very big) from the bat to the headlight, just stick it in the back of the plug. I did this and you can see how much brighter the lights get. I got relays but havent installed yet. I thought about making up a couple harnesses for our trucks and try to sell a couple. Think there would be much interest in a plug and play relay harness?
Old Jan 14, 2010 | 08:41 AM
1986F150six's Avatar
1986F150six
Crankylove, do an Internet search before buying Sylvania Silverstar headlamps. I installed them in my son's 1984 F-150 and they perform very well, but both of the lights (low beam) have burned out in about a year. There are many reports of the same thing. Sylvania explains that due to the high performance nature of the lights, they cannot be expected to last as long as more standard halogen bulbs.
bashby, LMC offers a plug and play headlamp relay harness, at least they did about a year ago, but my understanding is that it comes with lower quality Chinese manufactured relays.
Old Jan 14, 2010 | 08:46 AM
NavyMIDN08's Avatar
NavyMIDN08
LMC still has the harness listed on their online catalog. they also have the euro style headlights. hmmm... i wonder how those euro styles would look...
Old Jan 14, 2010 | 05:39 PM
bashby's Avatar
bashby
Damn! $30 from lmc. I'll have closed to that in parts to make my own, but I was going to make a 4 relay setup for plow lights also
Old Jan 14, 2010 | 06:59 PM
bghnkinf250
I priced the LMC one, but with shipping, it was about $40 or more.
I am going to run a wire from the batt to the headlight tonight to see the difference in brightness.
Old Jan 14, 2010 | 07:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I installed the LMC one when I did my 3G upgrade.
Yes the relays seem cheap. But the **additional grounds**and 'plug and play' head lamp sockets made everything brighter, and that load is not run through your dash harness.
I took the time to wrap everything up in harness. (the yellow and blue wiring are godawful)
So for me it was a simple, worthwhile upgrade.
Old Jan 14, 2010 | 07:24 PM
bghnkinf250
I am really wanting to do it, and I understand about not running it through the switch. I am a little hesitant because I did it on my 92 and it did not seem to make any difference.
Old Jan 14, 2010 | 07:41 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Did you add grounds direct from each socket?
Old Jan 14, 2010 | 07:43 PM
bghnkinf250
I actually forget if I did. I think so.....
Old Jan 14, 2010 | 08:13 PM
Crankylove's Avatar
Crankylove
Crankylove, do an Internet search before buying Sylvania Silverstar headlamps. I installed them in my son's 1984 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_8_0>F-150</NOBR> and they perform very well, but both of the lights (low beam) have burned out in about a year. There are many reports of the same thing. Sylvania explains that due to the high performance nature of the lights, they cannot be expected to last as long as more standard halogen bulbs.
I have had them in some of my other vehicles, and you are right, they don't last as long as a standard halogen, but I like the extra light they give while still using a standard plug. I appreciate the heads up though
Old Jan 16, 2010 | 12:28 AM
bghnkinf250
Well, I tried hooking the lights directly to the battery. It was noticeably different. I guess I will be going ahead with the relay.
