EFI Fuel Pump
Old Jan 13, 2010 | 09:36 PM
73'360f100's Avatar
73'360f100
EFI Fuel Pump
Does the EFI block have a port for a mechanical fuel pump. I'm thinking of converting an efi motor to carb and just wondering about fuel.
Old Jan 14, 2010 | 12:36 AM
Brigart's Avatar
Brigart
The fuel pump flat and mounting holes are there but no driveshaft opening.
Old Jan 14, 2010 | 02:47 PM
73'360f100's Avatar
73'360f100
Dang it, so what would be the best way of handling the fuel. I'm guessing electric pump with a good fuel pressure regulator, but what should I use.
Old Jan 14, 2010 | 04:05 PM
Brigart's Avatar
Brigart
More Information for BOSCH 69404
is one that rockauto recommends for your pick em up. 50 something dollars could find one cheaper, but that sounds like a decent one.
Personally I wouldn't sweat a regulator. As long as you are not pushing more psi then you carb needles can stop.
