351C questions...
Old Dec 25, 1999 | 02:19 AM
A-rod
Guest
Posts: n/a
351C questions...
Alright, here's a few questions that I hope you truck guys can help me with. I am planning to swap a hopped up 351 Cleveland for my tired 302 in a '72 Econoline van. Has anyone out there done this or seen this? It looks good on paper, but is it going to fit? Its going to be tight, so can anyone suggest good headers for this application?
One more question, and this is for you performance fellows: of the three big makers (Offy, Edelbrock, Weiand), which intake manifold will work best using 2v heads, but a 4bbl, 600cfm, Holley carb. (I'm talking HPs here.)
Thanks in advance fellas, Alex.
Old Dec 26, 1999 | 02:25 AM
micah's Avatar
micah
351C questions...
You might run into some trouble with the motor mounts. In the four or so years Ford produced the Cleveland, (I believe)it was never used in trucks. I aquired a Cleveland some years ago (still yet unfinished) and I do recall some talk from friends about how it wouldn't just "bolt right up." In any event, check out the mounts.
Old Dec 27, 1999 | 10:51 AM
Eric B
Guest
Posts: n/a
351C questions...
The 351C and the 302 share the same motor stands and mounts, different from the 351M/400.
Old Dec 27, 1999 | 07:04 PM
StockMan's Avatar
StockMan
351C questions...
