dwell angle
Old Dec 27, 1999 | 04:42 PM
charles_1's Avatar
charles_1
dwell angle
What should the dwell be at on a 352? Also at what rpm do you check it? Mine is showing 32 at 650 rpms (idle). Thanks in advance.
Old Dec 27, 1999 | 05:45 PM
StockMan's Avatar
StockMan
dwell angle
Generally, the rpm is set between 550 and 650 depending on model and transmission type. Dwell angle would be between 26 and 31 deg. Basic point gap starts at .017 inches. If you give specifics I'll try to pin down exact information for you.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Dec 27, 1999 | 06:06 PM
charles_1's Avatar
charles_1
dwell angle
I dont know the year of the engine. I guess I need to close the points just a little then to get it around 30. Thanks.
Old Dec 27, 1999 | 07:04 PM
StockMan's Avatar
StockMan
dwell angle
If your points are used it can be difficult to get the correct gap on them due to irregular wear, pitting or mis-alignment. I usually set my points then test dwell just to see if their within range. Good luck.
Old Dec 27, 1999 | 07:49 PM
Mulletwagon's Avatar
Mulletwagon
dwell angle
>30. Thanks.
To decrease the dwell angle you have to increase the gap; and vice versa. Just about all Ford V-8s require a 27 degree dwell. Better to be slightly on the low side since dwell tends to increase as the follower on the point set wears (and gap decreases).
Old Dec 27, 1999 | 08:06 PM
charles_1's Avatar
charles_1
dwell angle
The points are only a couple of weeks old but I just got a tach/dwell meter for christmas. Thanks for the responses.
Old Dec 28, 1999 | 07:15 AM
StockMan's Avatar
StockMan
dwell angle
Tim Hodgson
170
Dec 29, 2025 02:44 PM
JRB64
Jul 23, 2017 08:42 AM
ddlyarmbar
Jan 6, 2007 11:46 AM
cole_boy
Garage & Workshop
Jan 29, 2003 07:45 PM
Tedster9
Aug 5, 2002 08:28 PM
