1978 - 1996 Big Bronco
shifting??
Old Jan 13, 2010 | 01:07 AM
tazf250's Avatar
tazf250
shifting??
ok here is my question, if my bronco idles high can that cause it to shift hard? it shifts a little late and hard like its holding the gear too long. its a 94 351w auto 4x4 e4od. any ideas or help will be greatly appreciated. thanks
Old Jan 13, 2010 | 01:57 AM
greystreak92's Avatar
greystreak92
It can have that effect. Pull codes and check for vacuum leaks.
Old Jan 13, 2010 | 07:38 PM
b4hntn's Avatar
b4hntn
Yep. The happier the motor the happier the transmission. I was pleasantly surprised to find that every time I did something to help the engine the transmission responded with smother, lower shift points.
Old Jan 15, 2010 | 07:32 PM
BULLETPROOF4.9's Avatar
BULLETPROOF4.9
Purge valve. Had the same problem with my 96. Run the code to make sure, you may have to hit a couple of different parts houses to find someone who knows what it is.
