Sponsored by: Real Truck
2001 250 sd esof
Old Jan 12, 2010 | 10:25 PM
daliam32's Avatar
daliam32
2001 250 sd esof
Truck has esof, everthing i have read says if their is no power to the switch on the dash it is the gem. Is this correct???
Old Jan 13, 2010 | 05:19 AM
ReAX's Avatar
ReAX
I wouldn't expect so. 4wd is a part of the GEM, but I would start with the fuses. The way I expect the system to work is the switch informs the GEM what you want the transfer case to do, then it instructs the transfer case motor what to do. My expectation is that power may pass through the GEM for the switch, but it would take the GEM dieing to disrupt power to the switch.
Old Jan 13, 2010 | 08:43 AM
daliam32's Avatar
daliam32
All fuses seem to be fine, what order does all this work?there is no power at the transfer case either
Old Jan 15, 2010 | 10:07 PM
daliam32's Avatar
daliam32
anyone else have any input I would appreciate it. Fuses are all good no power at switch, and vacumme pump no power at transfer case,no 4x4 lights
Old Jan 16, 2010 | 06:35 AM
ReAX's Avatar
ReAX
Have you played musical relays yet?
Old Jan 17, 2010 | 08:10 PM
daliam32's Avatar
daliam32
yes i did try musical relays also, but no luck with that either...
Old Jan 21, 2010 | 05:48 AM
curtster122's Avatar
curtster122
daliam
Im having the same issue's with my '01 Excursion. I have been told by several ford techs that the GEM Module is faulty. I still can't justify spending $550 on a GEM Module and not know for sure this is the problem. I removed the GEM Module to inspect for water intrusion ( F-150's were notorious for this ), no water markings on any part of the module. So now im stuck like you..not sure what to do next..
Old Jan 21, 2010 | 05:53 AM
JonathanN's Avatar
JonathanN
Reading this has put a whole new light on my 4x4 shifter on the floor... I had thought about trying to add the switch on the dash for my 4x4, but I'm reconsidering it now... I hope you get it figured out.
Old Jan 21, 2010 | 07:44 PM
daliam32's Avatar
daliam32
definetly stick to the floor shift
Old Jan 21, 2010 | 07:47 PM
daliam32's Avatar
daliam32
Originally Posted by curtster122
daliam
Tankfully I can get one through a friend for about half price
Old Feb 22, 2010 | 11:46 AM
curtster122
I have checked over the 4x4 system once again and now there is no power going to the #15 fuse. In the owners manual one of the functions of the #15 fuse is for the GEM. Any one have an idea on where the power comes from and how to check if this is related to my problems..
Thanks Curt..
Old Jul 25, 2010 | 11:19 AM
Dutch930's Avatar
Dutch930
Did this solve your problem?
Old Jul 26, 2010 | 06:48 AM
curtster122
No this did not fix my problems. I still have no 4x4! My indicator lights will come on when starting the engine as though the self check is good. Installed a new actuator on the transfer case as notified by ford. Still no 4x4... Guess the GEM module needs to be replaced. I just dont have that kind of money right now to replace it.
Old Jul 26, 2010 | 07:35 AM
Dutch930's Avatar
Dutch930
I think my GEM is out also but hate spending that kind of money without knowing for sure that it will fix it. Thanks for responding!
rmilchman
Aug 18, 2011 03:46 AM
daliam32
Nov 27, 2010 09:26 PM
rugermack
Jul 25, 2008 09:13 PM
Biggziff
Mar 31, 2007 12:54 PM
hc130flyboy
Jan 18, 2005 07:56 PM
