Sponsored by: Real Truck
esof ?
Old Nov 26, 2010 | 09:59 PM
daliam32's Avatar
daliam32
esof ?
Whereis the correct place toask a esof qestion on a SD
Old Nov 26, 2010 | 10:14 PM
wallz's Avatar
wallz
Here is good, just make sure to list the particulars of your truck.
Old Nov 26, 2010 | 10:24 PM
daliam32's Avatar
daliam32
2001 250 SD. 4 wheel drive does nothing.No power at dash switch,no power at transfer case,power on trasfercase relay by brake booster power on middle wire of vac pump,there is also vaccum problem with heat and ac which I can not find any leaks,oh and also hooked up new vac pump any ideas
Old Nov 27, 2010 | 07:16 PM
daliam32's Avatar
daliam32
Anybody give me a clue?
Old Nov 27, 2010 | 09:26 PM
RKern's Avatar
RKern
All of my esof problems have been vacuum leaks with the hub or pump on the passenger's side of the engine compartment. Usually when this happens your heater and ac will default to the defrost position no matter what the select lever says (when you attempt to engage 4 wheel drive. I finally got tired irritated and installed Warn Premiums hubs. Also about 2 or three threads down is another esof problem with many more detailed posts including wiring diagrams and voltage tests hope this helps.
gvb
Sep 3, 2011 04:17 PM
rmilchman
Aug 18, 2011 03:46 AM
rugermack
Jul 25, 2008 09:13 PM
Biggziff
Mar 31, 2007 12:54 PM
hc130flyboy
Jan 18, 2005 07:56 PM
