360 2V carb
Old Jan 12, 2010 | 02:35 AM
TexasTrash's Avatar
TexasTrash
Question 360 2V carb
So my question is, does anyone know if the 1975 F-100 with a 360 2V engine came with the motorcraft 2100 or the 2150 carburetor. My truck had a different carb on it when i got it. I'm pretty sure i have a 2100 on it now, but their is no spot to hook up the kickdown linkage.
Old Jan 12, 2010 | 04:51 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Either carburetor would have provisions for the kickdown linkage. It sounds like you have a carburetor for a manual trans. equipped truck.
Old Jan 12, 2010 | 07:04 AM
Kalve's Avatar
Kalve
How do you tell if the carb is for a manual or auto trans? I have a manual trans.
Old Jan 12, 2010 | 09:10 PM
fmc400's Avatar
fmc400
MSEE
Carburetors equipped for an automatic transmission have a kickdown linkage on the driver side of the carburetor. It's a lever with a slotted stud for which the kickdown rod slides on to, secured with an E-clip. Carburetors equipped for a manual transmission simply have the throttle linkage connector with no kickdown linkage.
