another noise for the board
Old Jan 9, 2000 | 12:39 PM
bigblockhead's Avatar
bigblockhead
I have a 73 Ranger witha 390,C6 and under half to full throttle it makes a loud noise that sounds like metal slapping against metal. It will not make the noise in park only when in drive. It sounded like a bracket or something had came loose but everything seems fine and tight. The noise started on one day last week and hasnt gotten any better or worse. No noise in idle or park when you goose it but only in drive with halk to full throttle. Oil pressure doesnt change and drivability doesnt change whem it make the noise. Could it be the tranny? It sound like its coming from the passenger side of the motor but then again , Im in the cab so I guess it could be comimg from somewhere else. Thanks in advance.
Old Jan 9, 2000 | 04:11 PM
StockMan's Avatar
StockMan
It may well be the transmission, but if driveability is not affected then it is likely something simpler. Perhaps a loose flexplate or torque converter, driveshaft or u-joint. Also check your motor and trans. mounts and the cross-members. No substitute for cover-alls and a light while nosing around underneath.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Jan 9, 2000 | 04:53 PM
bigblockhead
Thanks stockman, I kinda thought it was probaly something in the drive shaft or tranny but Im always looking for that easy fix or miracle cure. (never gotten one though) Guess Ill have to buy new batteries for the flashlight and put on the thermal coveralls cause its cold out there.
Old Jan 9, 2000 | 05:04 PM
StockMan's Avatar
StockMan
If all else falls get out the BFH. That is truly the "wonder" cure.
Old Jan 9, 2000 | 05:13 PM
bigblockhead
I know I dont even want to know, but whats a bfh?
Old Jan 9, 2000 | 05:22 PM
StockMan's Avatar
StockMan
Old Jan 9, 2000 | 05:35 PM
Bill at Hardcore4x4
Guest
Posts: n/a
B F H . Big F@#%^&* Hammer ! Now for your problem. Could be the rearend,If a tooth is chipped it will make a rapping noise under load but quiet when coasting Also could be bearings or u joints will have to check . Try revving the engine when in neutral .If it rattles it could be rods.How about reverse? .If its in the trans it will probably be the thrust washers getting worn
Old Jan 9, 2000 | 06:54 PM
bigblockhead
Well lets hope that I dont resort to the bfh. Ill start checking things tommorrow. Thanks again for the ideas.
Old Jan 9, 2000 | 10:28 PM
Bill at HARDCORE 4X4
Guest
Posts: n/a
