351-400m
Old Jan 7, 2000 | 02:14 PM
Like M. Fords's Avatar
Like M. Fords
351-400m
Old Jan 10, 2000 | 07:10 AM
rick's Avatar
rick
351-400m
Does anyone know if the 351-400m engines are supposed to have an "oil slinger" installed on the crankshaft right in front of the crank timing gear? While changing out the timing chain & gears in my 400 I noticed it did not have one.
I have gone thru a number of 351C type motors of the 1971-1973 vintage and they all used the slinger. (it looks like a thin stamped steel washer with a bent edge)
thanks, Rick
Old Jan 10, 2000 | 07:44 AM
Travis DuPriest
Guest
Posts: n/a
351-400m
I have a 400 also. Ford,for some reason put oil slingers in the passenger car 400 & 351m's. But they didn't in the truck engines. Why ask Why? Also a lot of passenger car motors had about a 3/4 " water pump spacer. again, Why ask Why? Not knowing for sure what my motor came out of, I put it together like the truck set up. No water pump spacer, or slinger. I have about 2500 miles on it now with no leaks. I also highly recommend fel-pros premium gasket set. It came with a ford rear seal, and rubber valve cover gaskets. I would recommend you to get the front seal from ford.
hope this helps.
Old Jan 10, 2000 | 07:47 AM
travis's Avatar
travis
351-400m
I guess I should have read a little closer. You wont need a full gasket set just for your timing chain change. ooooppps.
Old Jan 10, 2000 | 09:25 PM
rick's Avatar
rick
351-400m
thanks for the info Travis, I'll probably just stick it back together just like it was with no slinger.
Rick
theonlybull
Jan 13, 2003 08:04 PM
Nathan
Jan 13, 2003 05:43 PM
shazam
Jan 12, 2003 08:48 PM
fordmando
Nov 5, 2001 10:56 PM
Nathan
13
Apr 18, 2001 02:10 AM
