Steering feels loose after front end conversion.
Old Jan 30, 2010 | 06:17 PM
2000expedition4x4's Avatar
2000expedition4x4
Originally Posted by ronjeremy6
have you gotten used to this? my next project is the conversion kit from strutmaster. i don't want the drive quality to differ.
i really wish I could figure out how to disable the compressor without turning off the variable-assist steering. Other than that it rides as good if not better without any worry for leaks.
Old Jan 30, 2010 | 06:26 PM
fordtech08's Avatar
fordtech08
disconnect thesolid state relay behind the front bumper passenger side
Old Jan 30, 2010 | 06:29 PM
fordtech08's Avatar
fordtech08
or pull fuse 109 from battery junction box
Old Feb 2, 2010 | 12:32 PM
2000expedition4x4
Pulling the fuse did the trick. Thanks a lot for the troubleshooting. I owe you a beer
Old Feb 2, 2010 | 01:18 PM
fordtech08's Avatar
fordtech08
well about time we got it fixed
Old Mar 27, 2010 | 08:42 AM
2lionel's Avatar
2lionel
Hello 2004expedition4x4,
I am in the process of installing the 4wd kits from strutmaster on my 2001 Navigator. So you turn your air suspension switch on the passenger side off or is it on? Also fuse 109 helped your steering now that you pulled it. Is your check suspension light still on?
Old Mar 27, 2010 | 01:23 PM
2000expedition4x4
if the navigator is the same as the expedition then you want to pull the fuse and leave the passenger side switch on. This will disable the compressor while leaving the variable assist steering on.
Old Mar 27, 2010 | 09:22 PM
2lionel's Avatar
2lionel
Ok Thanks for the info, I will pull the fuse, I finished the rear install today the truck sits pretty good I also opted to just pull the buld on the check sus light. The instructions found here were exact and easy
Old Aug 13, 2010 | 01:04 PM
pablocruz69's Avatar
pablocruz69
I have a 97 4.6l, and my steering feels loose also. I have replaced the front shocks, and the steering box about 5 years ago. I was looking at the bushings for the upper control arms and they are cracked and they dont appear to be in very good condition. could all of these bushings be causing the loose feeling?
Old Aug 13, 2010 | 06:23 PM
Moto Mel's Avatar
Moto Mel
This should be a new thread.
Your problem could very well be the upper control arm bushings base on your description, the ball joints are probably worn out too.
blackburb
Jan 22, 2017 08:28 AM
mwells
Dec 29, 2014 09:13 PM
Lusitana
Dec 9, 2013 03:56 PM
KhanTyranitar
Aerostar
53
Aug 31, 2013 08:34 PM
bigshotsho93
Jul 3, 2010 07:39 PM
