C6 Passing Gear
Old Jan 12, 2000 | 09:44 AM
bigblue's Avatar
bigblue
C6 Passing Gear
On a C6 tranny, when you punch it and it kicks down to a passing gear, is that the same as second gear? I have a 1/2" carb spacer and the kickdown rod does not reach until I find time to modify it on my 78 4x4 351m. I am wondering if it is ok to just drop it into 2nd gear when I am going 50-55mph?
Old Jan 12, 2000 | 09:50 AM
Boss_358's Avatar
Boss_358
C6 Passing Gear
Iv'e seen people downshift into 1st going that fast. There tranny's didn't last that long but it should be safe. I had to do this with A t-bird because some hack was too lazy to put the kickdown back on after rebuilding the engine.
Old Jan 12, 2000 | 09:52 AM
Boss_358's Avatar
Boss_358
C6 Passing Gear
I meant to say that it should be safe to shift into 2nd not 1st if that is what I led you to believe.
Old Jan 12, 2000 | 01:03 PM
charles_1's Avatar
charles_1
C6 Passing Gear
I dont have a kickdown on mine either so I do it manualy. It will not hurt anything, its doing the same thing as the kickdown. Also, as far as shifting into 1st going 55 mph,I thought that the C6 would not allow it to go in at that high of a speed. I know if I throw mine into 1st going that fast it just goes into 2nd. I mean, I wouldnt run out and test this on your truck but thats how I thought they all were.
Old Jan 12, 2000 | 06:54 PM
jowilker's Avatar
jowilker
C6 Passing Gear
bb Yes to both of your questions
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Jan 13, 2000 | 08:41 AM
Boss_358's Avatar
Boss_358
C6 Passing Gear
OH yeah, it wasn't a C6 that they were doing this to, it wasn't even a ford. That must have been why it didn't last. My C6 does not shift into first until I am almost stopped.
Old Jan 13, 2000 | 10:45 AM
tazfords's Avatar
tazfords
C6 Passing Gear
it's ok but I suggest when you dou ,do it as if you were kicking into passing gear {in other words punch it enough to pass and come out of 2nd when rpms are just about to peak } i've done it many times
Old Jan 13, 2000 | 03:10 PM
D. Bellis
Guest
Posts: n/a
C6 Passing Gear
I would advise against it, That downshift rod works the downshift valve in the valve body. It's function is to increase line pressure so during periods of hard acceleration the affected clutches won't slip. make the rod longer so it will work. It probably won't hurt for a day or two, but we all know that a day or two usually turns into about six months. At that time your tranny may be cryin the blues!
Old Jan 13, 2000 | 11:31 PM
Tyler Bennett
Guest
Posts: n/a
C6 Passing Gear
Yes, it's ok to put it itno second gear at 60 mph. Do this, Go about 35 or so and drop into third, you sould notice that nothing happens until about 25 when the trans shifts down, regardless of the drive lever position. It knows it's own limits.
Old Jan 14, 2000 | 12:07 AM
mk's Avatar
mk
C6 Passing Gear
JoeSoCalif
1997 - 2003 F150
Apr 26, 2009 07:59 PM
jenkinsj
Jul 5, 2007 07:23 AM
just1me
Jun 19, 2006 07:20 PM
fecampbell
Aug 17, 2005 07:25 AM
fecampbell
1997 - 2003 F150
Aug 16, 2005 04:41 PM
