AOD Tranny question
Old Jan 9, 2010 | 09:43 PM
OldSkewl 79's Avatar
OldSkewl 79
AOD Tranny question
Hi guys..
I got a 79 with a 302. 2 wheel drive.. thinking about upgrading the tranny.. would it be possible to swap in an AOD tranny in place of the C4?
just curious if there is any hidden problems / obsticles
Thanks
C
Old Jan 9, 2010 | 10:00 PM
Conanski's Avatar
Conanski
Yeah that will work, you'll just need to connect the TV cable to the throttle linkage and set the cable preload correctly. If this is coming off a donor vehicle have a look at how it's setup at the throttlebody end and either make a bracket to do the same or buy an aftermarket cable, Lokar makes a cable and bracket for carb engines, part numbers Cable: KD2AODHT and Bracket: SRK4000. Also be aware you must use an AOD flexplate and not the C4 flxplate.
Lokar KD2AODHT - Lokar Stainless Steel Hi-Tech Kickdown Kits - Overview - SummitRacing.com
Old Jan 13, 2010 | 06:40 PM
JJ98's Avatar
JJ98
they make kits to just look on line at mustang places or just punch in aod swap and you will find lots of stuff or maybe some info you might have mist
