core plug problems
Old Jan 9, 2010 | 09:07 PM
wally4684's Avatar
wally4684
core plug problems
I bought a 92 F350 that the guy had pulled the trans out of cause of problems, but in the procwss of getting the trans back in, i saw that 2 of the core plugs were gone, 1 above the starter doesnt look hard to replace and the other in the middle on the drivers side looks to be a problem with the motor mount. any one ever replaced or changed the plugs in the truck and can i just take out the motor mount to replace the drivers side ? what would cause them to come out ? There no water in the oil, but that could be cause it ran out before it had a chance to leak in.
Thanks, Dan
Old Jan 10, 2010 | 01:51 AM
Hitokori's Avatar
Hitokori
hmm y did the guy pull the trans? was it trans problems or engine problems?
idk if u can put that one in with the engine in but i do know u can get some of those temporary ones and put them in and they will last long enough for u to find out if it has any major problems....
<!-- BreadCrumbs are not required if we are coming through punchout -->HomeReplacement PartsEngine Parts and MountsFreeze Plug - Rubber › Motormite Freeze Plug - Rubber Expansion
******** language=javascript type=text/javascript src="/wcsstore/CVB2BDirectStorefrontAssetStore/javascript/jquery.jqzoom.pack.js">*********>******** type=text/javascript> $(function() { var zoomOptions = { zoomWidth: 235, zoomHeight: 235, showEffect: 'fadein', fadeinSpeed: 'medium', hideEffect: 'fadeout', fadeoutSpeed: 'fast', title: false } $(".jqzoom").jqzoom(zoomOptions); }); *********>
any way thats what they look like and they will last long enough... well out last the engine actually but i wouldnt leave them in forever they are a temp fix
try it and c if the engine is all jaked up and fubared it will save u a little labor
Old Jan 10, 2010 | 11:46 AM
wally4684's Avatar
wally4684
He told me that the trans was skiping 3rd gear. The truck is a 4 door and I had been wanting one for a long time, but is was a 2wd dually and I wanted a 4wd single wheel, so I converted it over found a trans on here and had t-case and dana 60 front. It wasnt really a hard swap just grinding all the rivets out of the 2wd brackets and drilling some new holes for the 4wd brackets.
robjs111
1978 - 1996 Big Bronco
Apr 2, 2012 01:20 PM
holymolie
22
Mar 29, 2011 12:54 AM
Eston Newbern
Nov 14, 2010 07:14 PM
sidexside16
1997 - 2003 F150
Mar 14, 2009 07:39 PM
skelator
Sep 19, 2004 12:54 AM
