fuel tank sending unit
Old Jan 9, 2010 | 07:14 PM
driller tom's Avatar
driller tom
hey guys! I think that the sending unit for the rear tank in my 86 is going bad.... I filled the tank today and the gauge showed 1/4. Im planning on putting a new 38 gallon tank.... should I replace sending unit?
Old Jan 9, 2010 | 07:24 PM
dustybumpers's Avatar
dustybumpers
not until you put in the new tank, they're different. just carry a couple gallons in a can in the back until you make a switch. for emergencys
Old Jan 9, 2010 | 08:03 PM
driller tom
I was just looking at LMC truck and seems there are 2 different types of sending units... A mechanical fuel pump located on the engine and an electric pump mounted on sending unit in tank. How do I tell which one I have?
Old Jan 9, 2010 | 08:10 PM
Franklin2's Avatar
Franklin2
Follow the fuel line down from the carb. If you run into a fuel pump mounted down low on the side of the engine, then you have a mechanical pump. I would bet you have a electric one in the tank though.
Old Jan 9, 2010 | 08:30 PM
driller tom
Thanks guys!!
diesel77
Jul 28, 2020 11:52 PM
Beastie
Mar 3, 2015 04:55 AM
uh60
Oct 20, 2013 10:13 AM
raye321
Aug 11, 2013 03:06 PM
mike L
Aug 17, 2004 11:03 PM
