02 7.3l developed a pull when i hit the brakes it pulls to the right even when i put it in neutral so i dont think its the rear end. ive also replaced both front brake lines and the left calipar.... any help? i think my next option is to replace the rear lines! any ideas? thanks
ya i lubed the front pins. maybe i should lube the back pins! today i replaced the rear rubber brake line that comes off the frame bracket to the rear end. still pulls but a lot better ! off to lube the pins thanks for the help !!!!
Have you installed the caliper slide pin upgrade? Mine pulled to the left until it finally got stuck and I had to replace the pins. It still pulled a little bit to the left until I replaced the ball joints.
dont know where you are at but I had a problem similar to this but ONLY when it was really really cold, Dont know what actually fixed it as I changed pads and calibers and it still did it I bled the brake lines and and had already changed the fluid in the reservior this seemed to work but it also got warmer out, I have not had this problem in a long so what fixed it, I am not sure, just glad it was gone.
ya i replaced my ball joints and tie rod ends about 3 months ago. so im pretty sure its not a loose part . i think im going to get the fluid flushed. it is black! it seems to be a lot better after i lubed all the slider pins. but still a little pull. thanks for the input !
