brake problem
Old Jan 8, 2010 | 10:25 PM
02-7.3l-toy's Avatar
02-7.3l-toy
brake problem
02 7.3l developed a pull when i hit the brakes it pulls to the right even when i put it in neutral so i dont think its the rear end. ive also replaced both front brake lines and the left calipar.... any help? i think my next option is to replace the rear lines! any ideas? thanks
Old Jan 8, 2010 | 10:54 PM
big poppa's Avatar
big poppa
My first guess would be, did you lube the slide pins?? They get brake dusted up and coroded from the elements.
Old Jan 9, 2010 | 11:28 PM
02-7.3l-toy
ya i lubed the front pins. maybe i should lube the back pins! today i replaced the rear rubber brake line that comes off the frame bracket to the rear end. still pulls but a lot better ! off to lube the pins thanks for the help !!!!
Old Jan 10, 2010 | 12:04 AM
mechelement's Avatar
mechelement
Have you installed the caliper slide pin upgrade? Mine pulled to the left until it finally got stuck and I had to replace the pins. It still pulled a little bit to the left until I replaced the ball joints.
Old Jan 10, 2010 | 01:12 AM
knight60626's Avatar
knight60626
dont know where you are at but I had a problem similar to this but ONLY when it was really really cold, Dont know what actually fixed it as I changed pads and calibers and it still did it I bled the brake lines and and had already changed the fluid in the reservior this seemed to work but it also got warmer out, I have not had this problem in a long so what fixed it, I am not sure, just glad it was gone.
Old Jan 10, 2010 | 12:15 PM
02-7.3l-toy
ya i replaced my ball joints and tie rod ends about 3 months ago. so im pretty sure its not a loose part . i think im going to get the fluid flushed. it is black! it seems to be a lot better after i lubed all the slider pins. but still a little pull. thanks for the input !
nvrsadi
Nov 7, 2014 03:05 AM
bstarz40
Nov 23, 2012 05:35 PM
powerstroker02
May 13, 2011 12:07 PM
RodHoffmann
Apr 30, 2011 10:41 PM
Gr8ride
Jun 23, 2005 07:12 PM
