AE on an E99 with a '00 PCM
PCM, ONLY the PCM or else you could mess up your GEM. I learned the hard way
Clay, enlighten me a little on what the problems could be. We put a later model PCM in an early '99 but have used the '99 year on the AE, I think.
Don't you guys ever sleep?
Huck, thanks for asking the question. You may have saved us some problems. It does make sense though since you are monitoring the info through the PCM.
According to AE, it has to know what PCM that you are using so that it knows the correct calibration codes. I am not sure why it messed up my GEM, but I was just in a hurry and forgot to double check which PCM I had in at the time since I had been swapping them back and forth and testing.
