Sponsored by: Real Truck
Wont start when cold
Old Jan 8, 2010 | 04:32 PM
FL_Smokin_PSD's Avatar
FL_Smokin_PSD
Hey guys, i have a 2000 F350, 7.3. Its got DP_Tuner, ITP fuel setup with adjustable pressure, straight piped, and a DIY air filter. Problem is my truck does not want to start when cold. I have to try for almost 20min. It wasnt that big of a deal because i live in FL but with the colder weather it almost kills my batts before it fires. And now i have to go to Wyoming in a few weeks, it will never start there. What is the sensor on the intake, mine is broke. Its in the middle towards the back.
Old Jan 8, 2010 | 07:31 PM
senix's Avatar
senix
glow plugs...i would check them. Do you have the block heater on that truck? Plug in about 3 hours before you wanna go..put it on a timer.
Old Jan 9, 2010 | 09:21 AM
FL_Smokin_PSD
How do i check glow plugs? No block heater.
Old Jan 9, 2010 | 09:44 AM
F350-6's Avatar
F350-6
First check your GPR (glow plug relay) There's 2 large posts on the relay.
The one under the rubber boot should show 12 volts at all times. The other large post should only show power right after the key is turned on for up to 120 seconds depending on the temps. If there's no power on the 2nd large post, hold a screwdriver across the 2 large posts for 30 seconds and then try to start the truck.
To check your glow plugs, disconnect the flat connector at the center of each inboard head. You'll see 9 flat pins inside there. Grab an ohm meter and check the forward two pins and the rear two pins against battery ground. A reading of less than 2 ohms indicates a good glow plug.
Old Jan 19, 2010 | 06:35 PM
schmidtz's Avatar
schmidtz
Hi, I know from experience that in FL you don't use the glow plugs much. But here in Colorado, they are needed almost every day. I have replaced the glow plug relay twice since 2004. Each time it has corrected the problem. Its easy to troubleshoot, I don't short the terminals, if I don't have 12 volts on the output, it isn't working. My question is "why does it keep failing?". Is the relay under rated or is there a problem with the glow plugs? At any rate check your relay, you'll need glow plugs in Wyoming!
Blapensee
6.7L Power Stroke Diesel
Feb 13, 2015 12:48 AM
got2befast
Feb 10, 2011 07:48 PM
Raider50
Wyoming Chapter
Jul 28, 2008 12:53 PM
armynavyguy
Modular V10 (6.8l)
18
Jan 29, 2008 04:15 AM
