Sponsored by: Real Truck
Help Upfitter Switch Install 09
Old Jan 9, 2010 | 05:11 PM
bayou barataria's Avatar
bayou barataria
The plug is way the heck up above the steering column, you have to really get in there to find it.
Old Jan 10, 2010 | 12:55 AM
Skeeter363's Avatar
Skeeter363
Originally Posted by senix
they came out in 06 I believe...mine was an 06 and had them..they are accessory switches.
Here is the guide for 2006: https://www.fleet.ford.com/truckbbas/non-html/Q133.pdf
Thankyou sir!
Old Jan 10, 2010 | 07:06 AM
senix's Avatar
senix
Originally Posted by Skeeter363
Thankyou sir!
You're welcome!
Old Jan 11, 2010 | 06:16 AM
DDDTriggerman's Avatar
DDDTriggerman
Originally Posted by Eugene Thompson62
The wire harness is at the very top of the dash, just to the right of the fuel peddle. The factory installed a black plastic boot in the connector, I guess to protect the pins. Look at the connector and make a mental thought of it so that you can match it up. Take the black plactic boot out and you can install the connector. I could not figure how to route the harness and use the factory plastic plugs in the factory holes so I used zip ties. They worked great. The only hard part will be fishing the connector up to where it plugs into the rear of the up fitter switches. The assoc. wires are under the dash just to the right of the parking brake. Any question just givce me a shout. Hope this helps.
Thanks for the help - I'll give this a shot some time this week. Hopefully when it warms up. This 30 degree weather crap, is something us Floridians aren't use to.
Old Jan 11, 2010 | 06:01 PM
bayou barataria
Try 24 degrees here in new orleans, its been below freezing at night for over a week now. It has killed everything I have grown for the past three years.
Old Jan 17, 2010 | 12:50 PM
DDDTriggerman
Thanks for the help guys. I was able to find the plug. It was more up towards the firewall, than back up close to the instrument cluster where I was originally looking. I can say that was pretty easy once I found the plug. However, routing the wire through to the switch housing was a hole other story.
All is installed and well. Thanks again.
Old Jan 17, 2010 | 12:52 PM
senix's Avatar
senix
yeah, you almost need to take yoga before doing that one.
Piolet
Sep 27, 2022 07:59 PM
Skatermike24
May 2, 2017 01:39 AM
falloutboy89
Jun 10, 2016 01:15 AM
05 XLT 60 PSD
Dec 31, 2012 07:36 AM
strokersace
Mar 18, 2008 12:08 AM
