I recently put on a trailmaster 6" suspension lift on my 99 f250. its all put together. But I have 2 ssv shocks left over? I have all the 4 ssv shocks put on the truck that came with the kit. But I have 2 left because the kit came with 6. What are these other 2 for? There is no other bolt holes for them.
It appears that you have the F4521SSV kit, which includes two SSV (front) shocks. It also appears that a complete set of four SSV (front & rear) were ordered. I don't believe that Trailmaster offers a dual front shock setup so you apparently have two extra shocks for future replacement purposes or you could use the Rough Country kit that bbender85 provided.
Yes there for the front. Thank you!
That is the exact kit I have Furian. Its installed. I just need to put on my 37x13.50 mickey thompson mtz's. Will I have rubbing issues?
What size wheels are you using? Do you know the back spacing of the wheels?
I really want the tires to stick out from the truck, I like the look but the widest tire I can get is 13.50. The wheels are the dick cepek dc1's with a 4.5" backspacing and ither a -12mm or -16mm offset. One of those two for the offset. Do you think they will stick out far with this combo? I have yet to to put them on my truck yet.
A minimum of 4.5" of back spacing is recommended with the 1999-2004 Super Duties. However, if you are using 13.5" wide tires, then you are going to have rubbing issues with the front leaf springs. There was a lengthy thread on this issue (see link below). The 37" tall tires will rub the front bumper but you can trim the bumper as needed.
Got the Tires On. They dont hit the front bumper because I have a 3" body lift on aswell I forgot to mention. Anyways it looks like the tires will scrape at full turning. So is there any way to prevent this? Spacers maybe? If So where can I get some?
turn your wheels all the way(one way). make them hit the leaf spring then measure the distance between the turn stop and the spindle. take that measurement and add a little to that and thats what you'll need to add so that your wheels dont hit the leafs.
Alright I was hoping to get some wheel spacers anyways so the tires stand out more. Would anyone be able to recommend a good set?
i'll tell you i have a set on my truck. i have no problems but they are lug centric. you want hub centric. mine are 2" because i'm running coil spring wheels on a leaf spring truck. i think the place i bought them from is www.ezaccessory.com but like i said you'll want to run hub centric and i think they are three times the money. also your wheekls are alot wider than mine and you would be putting more stress on your front end parts. i know a fte member w/ the user name monsta has them on his truck maybe he can give you some info. if not give furian a minute hes incredible at getting people hooked up with links and photos. good luck.
also if you go smaller than 2" you'll have to trim your wheel studs. i really needed like 1 5/8 ths but i did'nt want to cut my wheel studs in case i want to put my old wheels back on.
