high tourque starter drags.
Old Jan 8, 2010 | 09:54 AM
LOWBOY1979's Avatar
LOWBOY1979
I just installed a high tourque staryer from a 96 460 onto my 79 F-250. The engine in the truck is a 73 lincoln 460. The problem is that the starter drags for about 5 seconds after I let go of the key. I checked the solinoid on the fender, it releases power with the key. I have a jumper wire from the main power wire at the starter to the (s) terminal at the starer. I thought it was the solinoid on the starter so I replaced it. the same thing with the new starter and solinoid. Any Ideas?. Thanks.
Old Jan 10, 2010 | 02:58 PM
peganit2's Avatar
peganit2
I need to know the exactitude of this myself. But if it's the same as other Ford engines, you need to match starters with the type of transmission, i.e. a manual starter has to go with a manual transmission and an auto starter has to go with an auto trans.
Old Jan 11, 2010 | 10:31 AM
LOWBOY1979's Avatar
LOWBOY1979
I did not even think about that. The starter came off of a A4LD. I bet thats what the problem is. Mine is a C-6. I will get a starter for the C-6 and let you know. Thanks.
Old Jan 16, 2010 | 01:27 AM
Prozon's Avatar
Prozon
You don't need to put a high torque starter on a stock 460, unless its something special, you'd do fine with a stock one.
rickpilgrim
Nov 20, 2012 12:07 AM
McKenny
Oct 15, 2011 11:19 AM
CDaddy
Oct 10, 2010 08:17 AM
Stuckinmud
1978 - 1996 Big Bronco
Nov 25, 2001 09:49 AM
vern
Feb 13, 2001 03:06 PM
