Sponsored by: Real Truck
Will Crank but no start
Old Jan 8, 2010 | 08:03 AM
TimmyG's Avatar
TimmyG
I'm working on a 2002 SuperDuty with a 7.3 powerstroke. The truck will not start, i checked the codes on it and here they are as followed
P1663-Fuel Delivery Command Fault
p1667 CID Circuit Fault
P0380 Glow Plug Circuit Fault
P1283 Injector Pressure Regulator Circuit Fault
I first checked to see if my glow plug circuit was working, from what i see everytihng working except when you turn the key on, there is no command from the PCM to activate the Glow Plug relay. I grounded the contact on the relay and the glow plug relay activated. NOw with all the other codes i'm wondering if i have a bad PCM, or am i thinking too deep into this and it might something more simple like a grounding issue
If anyone has seen or worked on something this messed up PLEASE let me know because i'm pulling my hair out right now
Thanx
Old Jan 8, 2010 | 08:39 AM
motown's Avatar
motown
You may want to check your fuel preassure, see what it is before starting it cold.
Old Jan 8, 2010 | 08:43 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE Tim
I'd suggest posting this in the '99-'03 7.3 section: 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Good bunch of folks over there....they'll get you pointed in the right direction.
Old Jan 8, 2010 | 08:55 AM
senix's Avatar
senix
how is the oil level in the truck as well. I hear if you are low on oil that can be an issue
mfp4073
1983 - 2012 Ranger & B-Series
Jun 17, 2014 02:38 PM
Krazymaan
Jun 13, 2011 10:19 PM
TimmyG
Jan 20, 2010 11:26 AM
dmulert
60
Apr 4, 2009 06:15 PM
