COP Question
Old Jan 7, 2010 | 10:29 PM
Reefmonster's Avatar
Reefmonster
COP Question
I have a 2000 Navigator , are all the COP for the 5.4 litre the same? I have a bad skip, I am assuming its time to change the packs and plugs, I found a couple sets online for a couple hudred dollars but wanted to make sure I dont order the wrong ones. Thanks, Joe
Old Jan 7, 2010 | 10:56 PM
fordtech08's Avatar
fordtech08
there are different cops
Old Jan 8, 2010 | 07:12 AM
l-m tech's Avatar
l-m tech
they are diff.and once you get in there you are probably gonna find oil in the bores from the o-ring gaskets that go between the valve cover and head leaking.its a common problem and a pain to fix.
Old Jan 8, 2010 | 11:10 AM
Reefmonster
So, how do I find out which ones I need, I want to get everything together before I start tearing it down?
Old Jan 8, 2010 | 01:32 PM
alloro's Avatar
alloro
The COP number that you need to search for is DG508.
Old Jan 8, 2010 | 04:45 PM
Reefmonster
Thanks for the info, I am gonna get new COPs and Plugs this week and hopefully start on the monster next weekend, it really looks to be a bear to get to these under the Navigators hood. Also on the list is a new power steering pump. Steering is extremely hard when sitting still or low idle, it gets better with more RPMs but is still tough.
Old Jan 9, 2010 | 07:13 AM
benningstspeed1.0's Avatar
benningstspeed1.0
DO YOU HAVE A 5.4L SOHC OR DOHC
SOHC = DG-508
DOHC = DG-512
Old Jan 9, 2010 | 07:34 AM
Reefmonster
SOHC = DG-508
DOHC = DG-512
I am not sure, how can I find that out, would it be written anywhere?
Old Jan 9, 2010 | 08:26 AM
fordtech08's Avatar
fordtech08
where are your coils at? are they in the middle of the valve cover then it's a DOHC if they are in your head between the intake and valve cover then it's a SOHC plus a DOHC is huge should be on your radiator cover
Old Jan 9, 2010 | 10:03 AM
ford12508's Avatar
ford12508
He has a DOHC I am pretty sure. It is a 4V that Ford introduced in 1999 to the Navi.
Old Jan 9, 2010 | 10:18 AM
fordtech08's Avatar
fordtech08
ford put three engines in that truck 4.6, 5.4 SOHC, and 5.4 DOHC
Old Jan 9, 2010 | 10:25 AM
ford12508's Avatar
ford12508
sorry about that then, I didnt know they put both SOHC and DOHC in it.
Old Jan 9, 2010 | 12:14 PM
Reefmonster
Looks as though the cops are right next to the injectors at the intake, does not look like they are in the valve cover. Just got the code checked and it is a cylinder 2 misfire, I belive that is the passenger side 2nd from front correct?
Old Jan 9, 2010 | 01:26 PM
fordtech08's Avatar
fordtech08
that is correct they go in order starting on passenger side 1-4 then driver side 5-8, 8 is in back
Old Jan 9, 2010 | 02:57 PM
Reefmonster
I was wrong they were under the valve covers, I guess it is a dohc engine after all
