1978 - 1996 Big Bronco
Cold Weather.. High Idle
Old Jan 7, 2010 | 09:01 PM
95FordTruck02's Avatar
95FordTruck02
Alright so since the cold weather rolled in the Bronc has been idling very high, around 1500 rpm. Before this cold snap it was idling around 6-800 rpm. Seems to be happening when the temps are down in the 20s.
The annoying part are the hard slams when I put it in drive/reverse from the high idle, but also that if I am cruising around 35-40 mph and let off the gas to coast it will then give a pulsing variance in rpms from 1000 to 1500.
Any ideas? Thanks!
Old Jan 7, 2010 | 09:59 PM
drunkdave's Avatar
drunkdave
sounds like a vaccum leak to me.
Old Jan 8, 2010 | 10:04 AM
95FordTruck02
That is what it acts like, maybe it just happened to start leaking when it started to get cold - ill check around under the hood and see what i can find.
Old Jan 8, 2010 | 11:51 AM
Kemicalburns's Avatar
Kemicalburns
are you letting the truck warm up good before you drive off? also do you have the antifreeze lines running to the throttlebody? if not you may have a tb that is sticking open due to the cold. I would pull codes
Old Jan 8, 2010 | 01:55 PM
95FordTruck02
Yes, I have been letting it warm up, the other day it backed down once the truck was good and hot, yesterday it did it all the time (although i never made any long trips)
I don't recall ever putting any antifreeze lines to the throttlebody when I rebuilt this engine, is that a standard setup on these engines?
Thanks for the help
Old Jan 8, 2010 | 03:05 PM
95FordTruck02
Ok I'm dumb - I went out and looked and there is a line running from the radiator to the throttle body, however even after running the engine to operating temperature that line was not really hot at all- coolant level is fine - is this typical?
Old Jan 8, 2010 | 04:45 PM
Kemicalburns
i wonder if that line isnt ran properly by chance. can you blip the throttle to make the rpms drop by chance? what temp Tstat did you install?
Old Jan 8, 2010 | 06:03 PM
95FordTruck02
Yes I can, like i said in the original post it hasn't been a problem until about three days ago when the temps dropped. Before that it had always idled fine, no problem like this. That line doesn't look like it could go any other way, so I'm not quite sure that it could be in improperly.
I am wondering though whether drunkdave may have had it right originally though on the vacuum leak idea as that is exactly how it acts, not so much a stuck throttle. A hard plastic line could have gotten brittle in the weather and snapped in the past couple days - this thing hasn't been driven in years. I think this weekend I will do some further searching around under the hood to see if there isn't a leak somewhere.
Old Jan 8, 2010 | 07:07 PM
drunkdave's Avatar
drunkdave
mine used to idle about 1500 rpms on first start up as well, and slam when put in gear. I had a massive vaccum leak. The idle would eventialy drop, and bounce back and forth between about 800 and a 1000 rpms.
Old Jan 8, 2010 | 07:17 PM
greystreak92's Avatar
greystreak92
The coolant line to/from the throttle body RETURNS coolant via the bottom hose to a point on the radiator just below the cap. However, the feed for the TB comes off a barb near the water neck If I am remembering correctly. Might want to make sure both lines are warming up.
The vacuum leak is the most obvious thing and with the hard plastic lines in some areas, they are adversely affected by the cold after a few years.
Old Feb 7, 2010 | 02:47 PM
95FordTruck02
Alright so it turns out the cold weather just happened to hit as this problem became noticeable.. no relationship. I got the codes using the flashing check engine light method and got two codes concerning the tps. I replaced it today and bam.. like a new truck. The RPM fluctuations are gone.. and no more slamming into gear. Also no more sluggish starts off the line... a problem that I didn't even think was related. Amazing how much effect that one sensor has on an engine.
While I had the throttle body off I also cleaned that coolant tube as it didn't look like much was getting through there. Thanks for the heads up on that.
Thanks for the help.
LARIAT 85
May 7, 2017 04:17 PM
chiefsfootball
16
Mar 28, 2017 01:40 PM
Preuett
Jan 11, 2016 04:57 AM
9902ford
Jan 15, 2013 06:53 AM
seventyseven250
Modular V8 (4.6L, 5.4L)
Jan 10, 2010 09:44 PM
