Accelarator Cable
If anyone has one or know of anyboby please let me know.
I do not have the money for a new one.
Thank you
Mine is only 20" according to the oem stock number. C5TZ-9A758-AH
There are several web sites I went to to get the part numbers.
oldreliable.com, blue oval truck parts and others I don't remember
The cheapest place was parts@parrauto.com this may be the e-mail address or ftepartsguy.com
John
1966 F100: There are three different throttle cables.
The Merc's use the same cable as the Fords.
C5TZ9A758AG .. Throttle Cable-28.66" long.
Fits: 1965/66 F100/250 240/300 I-6's except with 4WD and with T/E ( smog pump).
C5TZ9A758AE .. Throttle Cable-26.06" long.
Fits: 1966 F100/250 240/300 I-6's with 4WD.
C6TZ9A758K .. Throttle Cable-28.66" long.
No one makes a repop for the 65 66.
Garbz
There are several web sites I went to to get the part numbers.oldreliable.com, blue oval truck parts and others I don't remember.
The cheapest
The cheapest place? Uh huh...yeah right. Exactly where the heck did you get this info from?
parrauto is Parr Ford in Bremerton WA and has none of these cables, and hasn't had any for years.
C5TZ9A758AH has been obsolete since 1988, the last MSRP was $71.38. As of last month, NO Ford Dealer, NO obsolete parts vendor has any.
Over the past year, I've found 14 of these cables NOS at Ford dealers/obsolete parts vendors. Originally, I posted the info, but haven't recently, because...
The last time I posted the info, some greedy SOB bought all FIVE of the cables a dealer in GA had.
So...what I did was...I waited until an FTE member needed one, then P/M'd or emailed them the info. All have now been sold.
There was a C5TZ9A758AH cable on ebay recently. Bob's F100 Parts in Riverside CA (951-681-1956) is the seller and he's supposedly reproduced this cable.
Dave: Which one of these FOUR different 1980/86 cables will work? Inquiring minds wanna know.
Is it EOTZ9A758B (20 7/8")? Or is it E1TZ9A758B (21 1/2")? How about E1TZ9A758 D (19 3/4")? Mebbe it's this one: E4TZ9A758 D (22 1/2").
There are FOUR more, but all are longer than 25 inches.
Flynn: C5TZ9A758AE .. Accelerator Cable-26.06" long / Obsolete
Fits 240/300 I-6: 1966 F100/250 4WD // 1966 F350/600 / 1966 B500/600 (School Bus) / 1967/69 B & F500/600.
No Ford Dealer or obsolete parts vendor has any / 1965 F100/250 4WD 240/300 I-6 (F350/600 & B500/600) uses a different 26.06" cable (C5TZ9A758A).
I found FIFTEEN of these, but I dunno what the difference is, or whether it can be made to work.
I have used the 86 4x4 F150 cable with success. Whatever that part number it is. But as i stated you need the bracket to hold the end at the valve cover. They are plentiful in the salvage yards.
Most of everything up till 86 and even beyond can be installed on the 240/300 due to its long run from 65 to 96
Garbz
