Disc Brake Caliper
Old Jan 8, 2000 | 01:38 AM
Trail_Rider's Avatar
Trail_Rider
Disc Brake Caliper
Old Jan 22, 2000 | 08:00 PM
Brady's Avatar
Brady
Disc Brake Caliper
I just bought a 1976 f-100 4x4, and I thought the front brakes were bad so I put a new set. Well after I instaled the brakes I noticed that the caliper was rubing on the inside of the rim. I have normal 31-10-50s tires on the truck. Just wonderin if anyone else ran in to this problem.
Old Jan 23, 2000 | 03:23 PM
Trail_Rider
Disc Brake Caliper
Never heard of that one before. The closest thing I've ever come to that was when I tried to put (special order)8 lug 15" rims onto a 3/4 ton front axle. The rims wouldn't clear the calipers in the front.
Trail Rider
Old Jan 24, 2000 | 02:52 AM
BroncoJ's Avatar
BroncoJ
Disc Brake Caliper
Some aluminum aftermarket wheels interfere slightly with the caliper. If this is the case, you can safely grind a LITTLE BIT off the caliper.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
